Hydra-Rev kits...
No, as stated a rev-kit is a band-aide for those that don't know how to choose a spring for a given cam/rocker/rpm application. It is *really* helpful when you change a given combo and decide to add a rev-kit in lieu of changing out springs, thus it is considered a band-aide.
Manufacturers are also very good at recommending parts they sell to increase sales, thus most of the recommendations out there are from companies that also market them.
If you pick the right spring you will not need a rev-kit. And that goes for ANY application. I have built many high-hp and high-revving LT1s, which is much more 'real-world' than most that are posting on here, and none have needed a rev-kit.
And, if your main purpose to put a rev kit on is to 'save' the bottom end in case of catasrophic valvetrain failure you should also have standoffs on the center oil drainbacks and screens in the drainback holes on the ends, THEN run a rev kit to ensure you still have oil pressure if you are so worried about loosing a lifter.
The immediate discussion went towards how it 'helps' run a certain rpm (thus the name a 'rev-kit'), and the fact of the matter, for running a certain rpm you *should* be doing it with the proper spring.
I don't consider them a "gimmick". They do have their place. I have seen posts by well known engine builders who use them on the street. To each his own.
