How to put a lt1 crank hub back on?
Old 05-03-2009, 08:35 PM
trans am you lose's Avatar
Default How to put a lt1 crank hub back on?
What is the quickest way to do this? Im having a lot of problems.
Old 05-03-2009, 09:09 PM
LS1TECH Sponsor
Jon@BruteSpeed's Avatar
Get a harmonic balancer install tool. You don't want to beat your crank snout up and this will press her right on.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old 05-03-2009, 09:25 PM
RamAir95TA's Avatar
Having this makes life so much easier.
But if you don't want to spend the $50 on it, you can try and find a Grade 8 threaded 7/16-20 rod, a few BIG THICK washers and a Grade 8 nut, and press it on that way. I chose the hub install tool and am glad I did.
Old 05-03-2009, 10:15 PM
James Montigny's Avatar
You can rent an install tool from any parts store, you get a 100% refund when you bring it back.
I borrowed it so many times, I just went ahead and bought one LOL
It's essentially a threaded rod with a nice big nut and a thrust bearing.
Don't beat it with a hammer, you'll just ruin something.
Old 05-04-2009, 06:42 AM
SnakeOiler's Avatar
Nice pic, too.
I put one in my tool box first time my friend and I ever pulled an engine. I won't date myself with how ago that was, either
Old 05-04-2009, 01:26 PM
METALBEAST's Avatar
This is the easiest way to get the hub on . Used it several times. Takes maybe 5 minutes to put on the hub.
http://members.***.net/gmarengo/Misc/Misc.htm
Old 05-04-2009, 01:28 PM
ss.slp.ls1's Avatar
Most parts stores carry a standard harmonic balancer tool that won't fit through the small hole in the LT1 crank hub.
+1, that's what I did and it works great. Cheap tool that you can use over and over.
Old 05-04-2009, 01:52 PM
Javier97Z28's Avatar
I know everyone says "don't do it".. but I've probably done it 10-15 times..
Get a longer bolt, stack washers and pull it back on. Keep removing/adding washers as needed.
Finding a grade 8 7/16-20 threaded rod in a pinch isn't easy I found.
Old 05-04-2009, 01:55 PM
ss.slp.ls1's Avatar
Considering that this is from a GM manual,
http://shbox.com/ci/crank_sprocket.jpg
I don't think you will have any issues using a hammer to seat the crank sprocket or crank balancer. As long as you aren't pounding the **** out of it.
Old 05-04-2009, 02:12 PM
RamAir95TA's Avatar
There is a tremendous difference between installing the bottom crank gear and the crank snout. The crank gear is nowhere near as tight a fit as the crank snout, as it only takes light tapping to seat the gear.
The crank snout on the other hand is an extremely tight interference fit - pounding on it is not the correct way to do it. Your front main bearings will thank you for doing it correctly.
Old 05-04-2009, 02:14 PM
ss.slp.ls1's Avatar
I see what you are saying. Yeah, the crank sprocket goes on pretty smooth. For the record I have never used a hammer on the balancer because I made my own tool with a threaded rod, washers, and a nut. Works like a charm.
Old 05-04-2009, 02:24 PM
RamAir95TA's Avatar
Since you've never seen or done it yourself (thankfully), it takes a TREMENDOUS amount of pressure to seat the hub using only a hammer.
Old 05-04-2009, 04:31 PM
SoxXpupPeT's Avatar
i cleaned mine up real good and taped it on with a rubber mallet and then i used a longer version of the hub bolt with a washer and with alittle oil on the crank i screwed it on. just make sure everythings clean and you have afew washers so when you bottom the bolt out you can put more spacers on to get the hub on the crank flush
Old 05-04-2009, 04:36 PM
litch2004's Avatar
so if the part stores dont carry one that will work on our cars, where is the best place to get one?
Old 05-04-2009, 04:42 PM
ss.slp.ls1's Avatar
You make one.
Old 05-04-2009, 04:49 PM
litch2004's Avatar
o ok. im about to be putting my keyed crank hub on from thunderracing and i would rather not mess that one up.
Old 05-04-2009, 04:52 PM
ss.slp.ls1's Avatar
...you can try and find a Grade 8 threaded 7/16-20 rod, a few BIG THICK washers and a Grade 8 nut, and press it on that way.
^^^Do what what he said. That's what I did.
Old 05-04-2009, 05:03 PM
litch2004's Avatar
Ok thanks for the help
Quick Reply: How to put a lt1 crank hub back on?
