WTF Over???!!!
Old May 6, 2009 | 10:00 PM
Z28Camaro30Ann's Avatar
Default WTF Over???!!!
I'm baffled! Can you all do me a favor? Read the stats and all in my signature for Devon, the black 97 SS Camaro, and tell me if this sounds right to you! I think its WAY slow! Also I am at 600 Ft elevation.............
1st Run:
Reaction .5224
60 Ft 2.6645
330 Ft 6.7382
1/8 ET 10.0495
1/8 MPH 74.28
1000 ET 12.8741
1/4 ET 15.2415
1/4 MPH 95.30
2nd Run: (rpm's too low on launch, almost stalled)
Reaction .4735
60 Ft 2.7603
330 Ft 7.9528
1/8 ET 11.4235
1/8 MPH 70.32
1000 ET 14.3696
1/4 ET 16.8088
1/4 MPH 92.75
3rd Run:
Reaction .5103
60 Ft 2.6669
330 Ft 6.8210
1/8 ET 10.1301
1/8 MPH 74.34
1000 ET 12.9594
1/4 ET 15.3494
1/4 MPH 94.48
4th Run:
Reaction .3308
60 Ft 2.9216
330 Ft 7.2584
1/8 ET 10.6337
1/8 MPH 72.92
1000 ET 13.5140
1/4 ET 15.9388
1/4 MPH 93.09
5th Run
Reaction .3923
60 Ft 2.6614
330 Ft 6.7606
1/8 ET 10.0532
1/8 MPH 74.48
1000 ET 12.8780
1/4 ET 15.2530
1/4 MPH 94.98
6th Run:
Reaction .2753
60 Ft 2.7283
330 Ft 6.8565
1/8 ET 10.1697
1/8 MPH 74.16
1000 ET 12.9980
1/4 ET 15.3704
1/4 MPH 95.12
Seems slow as hell to me!
Old May 6, 2009 | 10:09 PM
nik1703's Avatar
seems like you've got big problems...
Old May 6, 2009 | 10:12 PM
AChotrod's Avatar
SLow is not the word. A blown up car could run that. Something aint right.
ElkySS's Avatar
ur 60 fts are worse than most civics i see.
a buddy of mine is in Denver at 6000 ft with a stock LT1 Camaro and ran a 15.1 with a 60 ft of 2.5 seconds....I am at a lower elevation, with a crapload more stuff done to the car, and he beats me??? REALLY?
Old May 6, 2009 | 10:13 PM
SoxXpupPeT's Avatar
your 60 foot is like your trying to launch on donuts. get that 60 foot down and you should see 13's
Old May 6, 2009 | 10:14 PM
trippinholyman's Avatar
sorry just read the post itself. you could maybe try fixing your 60 foot times, get them down a whole second and youll see 13s as said above. what kind of tires are you using? try underinflating them? like 20 or so psi i think is normally used, right guys?
Old May 6, 2009 | 10:15 PM
I would love to......but it wasnt me that was doing it! At 3000 RPM launch I bogged and sometimes almost stalled. At 3500 RPM launch I spun an INSANE amount......couldn't find a "middle ground" and that spin was almost half throttle
AChotrod's Avatar
No something is def wrong. My car Stock with DRs and a Cat back went 13.32@103
How high are shifting, what rpm are you leaving at? Is the car tuned? Obviously your on street tires?
1996firebirdformula's Avatar
Looks like you need some Mickey Thompsons
Its all about the 60 foot.
Old May 6, 2009 | 10:17 PM
Brand new Goodyear Eagle F1 275/40/ZR17 tires not even a month old, Corvette 9.5" rims, 3.73 Gears, 3000-3500 RPM launch, Manual, Eidback Springs, BMR SFC's, Eidback LCA's, BMR Strut Tower Brace, BMR Panhard Rod, stock tire pressure
Old May 6, 2009 | 10:19 PM
Shifting at 54-5600 RPM's
Puck's Avatar
PIBSAW - Problem Is Between Seat And Wheel . No offense but you need a lot more seat time. Those 60's are HORRID. I think a Geo on an oiled down track can match them.
Get the short times where they should be and your ET will plummet . Practice Practice Practice!!!
:edit: Damn just took a closer look at your mods. A 2.7 60' should not "almost stall" a HC LT1. Even with a crappy start it should mph much better then that - those are worst then stock trap speeds. Scan it, check for crossed plug wires, pull every plus and examine them, do a leakdown test, check fuel pressure, etc. because something is seriously wrong. I'm thinking at least two cylinders are not firing.
Old May 6, 2009 | 10:20 PM
I can't! Either I spun at half throttle, or I almost stalled, and all my launches were between 3000 and 3500
Old May 6, 2009 | 10:21 PM
what is a "good" 60 time?
Old May 6, 2009 | 10:22 PM
305 h.o.'s Avatar
Damn! My car cut 2.3-2.4 60's on street tires and still ran 14.1 at 101.86 with the clutch slipping all the way down the track. Your mph is way to low to ever see a 13. Switch the plugs to NGK's and check the Opti. Hell if you have cats they might need replacing. Sounds like the car cant breath.
Old May 6, 2009 | 10:23 PM
IronOutlaw's Avatar
I ran a while back and ran a, (dont make fun of me) 16.047 with a 2.514 60 foot. I still trapped 95.99 mph. That is with a cold air intake, gears and a homemade tune. I spun worse in second than first due to oil on the track.
Even with a bad 60 foot you should be trapping alot higher than that.
Old May 6, 2009 | 10:24 PM
AChotrod's Avatar
Well I had those tires b4 my DRs and could get 2.0-2.1 60s @ 28psi leaving at 3500, it would either bog or roast them. I shifted at 6k. Again my car was basically stock, your car should be doing way better than that.
Why is the 60 so bad? Does it just spin?
No CAT's, 3" exhaust, LT headers...Opti is brand new w/ MSD cap and rotor, new AC Delco Wires and plugs
Old May 6, 2009 | 10:26 PM
like I said... at 3500 RPM launch they went into a DEAD spin even at half throttle....at 3000 RPM launch, the car bogged and almost died....I had to double clutch to get it moving again
