Cracked Line/Hose Fuel Smell? (Pics Inside)
just loose the whole system.. https://ls1tech.com/forums/drag-raci...ap-delete.html
cleans up the engine bay too!
just remove the solenoid on the side of the engine.. cap the line going to the throttle body.. then remove the skinny line that runs along the front of the engine and connects to the third fuel line.. i just unplugged it and tucked the 3rd line into the fuel line protector/cover.. you could always go the step further and remove the charcoal canister but i dont think it's 100% neccesary.
i got some black tape for temp fix. Now my gas gauge isn't working guess it liked the fresh air LOL!
I know the EGR don't work. its unplugged at back vaccum hose harness. Kept pulsing at 55 mph.
Finally looked at the Codes.
It has P1661 something about computer/Aux mabe that why SES light don't work?
P1661
P0420
P0400
P0441
P1133
I Wrote them down and cleard them out. Drove it 5miles only code came back on was the P1661.
P1661
P0420
P0400
P0441
P1133
P1661
P0420
P0400
P0441
P1133
P1661
P0420
P0400
P0441
P1133
If you are getting code P1661 and your SES light doesn't work, then your bulb on the SES light is probably blown and causing the code. Pull your instrument cluster, remove the plastic cover on the back and pull the bulb that lines up the the SES light. It just twists a quarter turn and comes out.
Same thing happened on mine. I bought the car and over weeks of crawling around under it checking things out I kept noticing things that made me think "I can't believe thats not throwing a ses light". Then I noticed that the SES light wasn't coming on when you first crank up. I had noticed a Check Guages light and thought it was the SES light on these cars. I just happened to look at the cluster in the sun one day and noticed the outline of the SES light and that it wasn't working.
Kind of funny that the SES light can blow, throw a code, and you won't know it because the SES light is blown.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
