Guys running bigger rockers than 1.6 step inside
Old 05-16-2009, 10:00 PM
kierstyn's Avatar
Default Guys running bigger rockers than 1.6 step inside
I have a cc503 with ported heads and 1.6s and have been thinking about going to 1.65s or 1.7s. I have a few questions will the 1.65s work with the stock valve covers? I am pretty sure the 1.7s wont. Anything on the valve train i will have to change I have molly pushrods and springs good to 620 lift? Also can I run these in sa since my heads are set up that way? How much hp would I gain jumping up to one of these? Also if you are running bigger list what kind and a part# if you dont mind! Thanks, Kierstyn
Old 05-16-2009, 11:40 PM
JAKEJR's Avatar
I'm running Scorpion 7/16", 1.7s using 7.500 TrickFlow .080 wall one-piece hardened pushrods and CompCams guide plates on my 96 LT1 Vette.
I'm about to do a head and cam swap on my son's 96 LT1 Vette and am going that same route.
Although I tried, I couldn't get the stock covers to clear. I followed the grinding directions on Golen Engines website and couldn't get them to clear. I even ended up grinding a tiny hole in one of the valve covers before I gave up and bought a set of GM Approved ProForm 1/4" taller covers from Scorpion.
I don't believe 1.65s will offer any more clearance than the 1.7s did for me. Of course, my experience may be because of the Scorpion rockers, so those running Crane's or CompCams rockers may have a different results.
Also, I followed the advice of CompCams when one of their tech guys wrote, in essence, in a performance application, it's best to use a NSA valvetrain.
TrickFlow TFS 21407500 pushrods
SCP 1026 Scorpion 7/16" 1.7 RRs
CCA-4808-8 CompCams Guide Plates
Jake
West Point ROCKS!
Old 05-17-2009, 02:48 AM
itSSlowZ28's Avatar
also been wondering about this. what are the pros/cons of running 1.7's vs. 1.6's on a h/c or even just cam-only car? does it create any driveability issues?
Old 05-17-2009, 07:35 PM
kierstyn's Avatar
Bump I know theres more people running this setup!
Old 05-18-2009, 09:01 PM
kierstyn's Avatar
bump ttt
Old 05-18-2009, 09:14 PM
wrd1972's Avatar
I think there are fewer than you think.
Old 05-18-2009, 09:45 PM
snk-huntr's Avatar
running 1.7 scorpions on my ta , needed guide plates since there not self alighning used crane 10308-1 dual springs . moly 1 piece hardened push rods and barely got the valve covers to clear after hollowing them out .
Old 05-19-2009, 08:24 PM
kierstyn's Avatar
Yeah but there are a few! ^
Old 05-19-2009, 08:42 PM
snk-huntr's Avatar
also getting ready to install the cc 503, if you go through all the trouble do the 1.7,s not the 1.65,s go big.....
Old 05-19-2009, 09:38 PM
tspence45's Avatar
I'll be putting some Angus Racing 1.7's in my car sometime soon. But, I'm still on the stock cam. Sometime later this year I'll be running them with a cam though.
Old 05-19-2009, 09:45 PM
litch2004's Avatar
is there a big increase gain going from 1.6 to 1.7's?
Old 05-19-2009, 10:13 PM
94MichBird's Avatar
There's someone with a LT1 powered Jaguar on the board running 1.7RR and Comp Cam behives. I think his motor is close to stock with a few bolt ons. If I remember right it would be about .510INT/.521EXH with a stock cam. Probably 15-20 hp at the flywheel with a stock cam.
No way stock valve covers would work. You would probably need the frankenstein (Fabbed) valve covers. Valve guides would be a must, along with beefy pushrods, and 7/16 rocker studs. Oh Yeah, don't forget the valve springs..
Last edited by 94MichBird; 05-19-2009 at 10:15 PM. Reason: Forgot about the valve springs
Old 05-19-2009, 10:20 PM
tspence45's Avatar
If I remember, the guy with the Jag, picked up a good amount of whp going from the 1.6's to 1.7's. I think he reported a 10-15rwhp gain over the 1.6's. Of course, conditions, and weather factors could've came into play for the gain a little bit. But, that's still a pretty good amount, either way.
Old 05-20-2009, 02:01 AM
snk-huntr's Avatar
no ,maybe 8-10 horses at best.
Old 05-20-2009, 02:06 AM
JAKEJR's Avatar
There are quite a few guys running 1.7s. I've seen posts on other Forums, like LTXTECH.COM, CAMAROZ28.COM, etc. from guys running them. Probably Thirdgen.org and forums.corvetteforum.com too.
Jake
West Point ROCKS!
Old 05-20-2009, 11:36 AM
lt170chevelle's Avatar
I plan to run the 1.7 scorpion rockers with the stock cam here in the next few months, hopefully i will net a little more than 10 horsepower with 10lbs of boost. I did hear about some kinda geometry issues with the way the 1.7 rockers but im sure can be compensated with the correct legnth pushrod.
Old 05-21-2009, 03:19 PM
kierstyn's Avatar
Thanks guys!
Old 05-21-2009, 03:27 PM
oh yeah also i believe going from a 1.5 to 1.6 rocker you net a .030 increase in lift so hypothetically speaking maybe a 1.7 will net a .060 ish increase..this sound about right guys?
Old 05-21-2009, 03:34 PM
wrd1972's Avatar
And a bigger valvetrain beating overall.
Quick Reply: Guys running bigger rockers than 1.6 step inside
