rearend gear
Old Jun 26, 2009 | 08:26 PM
fx4offroad's Avatar
Default rearend gear
what size of rear gear is in the 1996 z28 thanks i think its a 373 not too sure any help
Old Jun 26, 2009 | 08:36 PM
Z28Camaro30Ann's Avatar
its not a 3.73. Not stock. Stock for the 97 SS was 3.42, and if I am right, a 96 Z Auto had 3.23's???
Old Jun 26, 2009 | 09:04 PM
ss.slp.ls1's Avatar
Yeah, M6 car was 3.42's.
A4 car's had either 2.73's or 3.23's. Not sure if the SS's all had 3.23's or not. You'd have to check your option codes.
Old Jun 26, 2009 | 09:05 PM
fx4offroad's Avatar
thanx so it might be a 3.42 i think its stock gear in thr rear end
Old Jun 26, 2009 | 09:08 PM
ss.slp.ls1's Avatar
If it's a 6 speed than yes, stock gears are 3.42's. Time to step up to some 4.10's.
Old Jun 26, 2009 | 09:18 PM
fx4offroad's Avatar
it a auto trans but im putin a turbo 350 and 3500 stall in it
Old Jun 26, 2009 | 09:59 PM
they only had stock 3.42's in the SS M6 though...not the Z28. He has a Z28 so they wont be 3.42's
Old Jun 26, 2009 | 10:01 PM
either way you look at it though he doesn't have 3.73's, so its definately time to upgrade...I am gonna go with 3.73's, but he has an auto so I think he should do 4.10 like slp said
Old Jun 26, 2009 | 10:33 PM
Chevyguy358's Avatar
I've run my 94' z28 w/ 3.73's with the factory 4L60E with bolt on 350, moderate HC 355 and then moderate 383---->converted T56 (383). I thought the 3.73's were the perfect gear for a 4l60E DD in all combos but alil to numerically low for the 6 speed...however your looking at a A3, guess it depends on your intentions and far high reving your motor is and tire size.
Old Jun 27, 2009 | 01:49 AM
tspence45's Avatar
All 6speeds from 94-02 had 3.42's.
Old Jun 27, 2009 | 02:47 AM
so the Z28 6 speed had 3.42's as well??? I thought it was only the SS's...
Old Jun 27, 2009 | 02:53 AM
whytryz28's Avatar
Turn the wheel, count how many times the drive shaft spins.
Old Jun 27, 2009 | 02:55 AM
whytryz28's Avatar
I had 3.08s in my 69' A3 camaro and they were the perfect gear for cruising and DD. Had I want to race it more, I would have went with 3.55 max.
Old Jun 27, 2009 | 03:38 AM
hitmanws6's Avatar
^^^ good method to check them. 2 1/2 turns means 2.73, just over 3 is 3.23. and btw 4.10s are way to big for an A4. IMO:
3.42s-For a DD who hits the strip every so often
3.73s-For a DD that is more focused on their 1/4 mile times
4.10s-For hardcore drag car
Old Jun 27, 2009 | 04:13 AM
ss.slp.ls1's Avatar
Who have you been getting your info from...really...???
Yes, ALL '94-'02 m6 fbody cars came with 3.42 gears.
Old Jun 27, 2009 | 08:46 AM
apparently some people who have no freaking clue what they are talking about....lol. I'm working on fixing that lmao
Old Jun 27, 2009 | 02:47 PM
ss.slp.ls1's Avatar
Good. Ask all questions here, and you will be someone elses resource soon.
Old Jun 27, 2009 | 05:19 PM
LT1's Avatar
LT1
RPO code rear gears 94-02
GU6 = 3.42 (all 6 speed Z28 - SS)
GU5 = 3.23 (3 series carrier)
GU2 = 2.73 (2 series carrier)
