Oil Pan Removal?
I am gonna be repairing the retarded job I managed to pull on my cam swap, so I will already have most of the bolts out so I can drop the front to get my Timing Chain Cover off...how much more would it take to just remove it and replace the gasket altogether???
It will be impossible without jacking up the engine. It just wont happen. you need to remove the two motor mount bolts. Raise the engine until the top of the trans hits the firewall/tunnel and then that should give you enough room to remove the pan.
