HELP! Lt1 D1SC is is misfiring after 4600rpm
I have a 96 LT1 396 D1SC with 12 pounds of boost at 4700rpm. The car misfires after 4600rpm. I had Bryan from PCMforless tune the car last fall and that's when we found the problem. I didn't have a MSD box and he said it was boost blow out. I put a MSD 6al box in and it still is doing it. The plug gap is .035 and it is a new opti spark. Could it be the opti spark? Any help would be greatly appreciated. Thanks Lee
Yea Valve Spring are for sure a possibility...
Did you loctite the rotor screws in the opti?? I had a 5400+ miss and an opti with less than 150 miles on it and the rotor screws backed out...
Also do you have an in car fuel pressure gauge or on you can rig up and tape to the front windshield for a test drive??
I had the same problem(on a stock motor, though). Have you checked all your plugs/wires for arcing? Try revving up the motor at night while looking on each side of your engine for arcing. I had a wire arcing, and also my coil was f'd up. New coil and wires/plugs and I'm fixed up for now. Probably gonna get an opti soon, though...lol
may wanna see what plugs though.... i personally run a ngk "tr7", non projected tip plug. its 2+ heat ranges colder than stock iirc... i run a .028 gap also but i could probably get away with a .032 or so...
7.65" / 3.4' d1sc 355 236/246 .624/.630 blah blah blah
I was gonna say pretty much the same. I run the TR6's at a .035 gap on mine. Never had a problem on the stock ignition setup. But your running a little more pressure than i was back then. I'd agree, check what heat range your running.
