Rear end swap
I'm hoping that's all that needs to be done. Should be easy right? Damn speed channel makes it look easy hah.
Since the e-brake setup is different on LS1 cars, you have two options. Either you pull the LS1 axles and brake backing plates and replace them with LT1 axles and backing plates/brake setup, or you convert your e-brake setup to the LS1, which is a whole extra project.
other then switching backing plates to accomadate your LT1 brakes its a straight forward swap. im gonna assume since your car is a 95 it doesnt have TC so it will be a 3 channel. so hopefully the 98 rear is a 3channel also. You can tell the channel: if there is a sensor at the top of the pumpkin its a 3 channel. if there are a sensor on each end of the axles tubes its 4 channel. If the 98 rear is a 4ch then you will have to use LS1 brakes in the rear
