Went to the track...
1) Left Short Term counts vary from 4% lean/rich at WOT even if BLM locker is used.
2) Timing is set at 33 in my tables and varies from 36-37 in the log. I have heard though that this is not uncommon.
3) Wideband afr ratio when lean in the mid 14s ran quicker than when rich in low 13s
Anybody have any ideas what could be happening?????
Im running and MSD opti. Don't know if it is failing as the dyno curves looked good and at the track the logs showed the timing was okay. I checked the plugs and wires they are good. I didnt feel any misfires but then again i dont have a crank sensor that checks for that since mine is a 94.
The springs are less than 2K miles old and have enough pressure on the seat for the cam and its lift numbers.
DA was really low like under 100 since the elevation at the track is only +5.
at idle i have it set a 43.5. what should it be at WOT? how do i check the pressure at WOT. my gauge is behind the manifold on the schraeder vavle. i dont want to have my head and hands all in the engine bay while its at WOT.
the logs show the trims at 128 on the right side but the left side is a little erratic if switches from rich to lean throughout the run.
If the banks arn't running even, maybe you've got a goofed up injector.
Specifics on the heads/cam?
heads are stockers ported & polished 2.02 1.6 valves. cam is a comp 224/236 574/572 111lsa.
the afr is tricky since i have to command a way rich afr to get something in the 12.7 range. id have to command like an 11 afr. on the dyno the car always made the big numbers at 11.8.
