Nitrous on stock/bolton only motor record?
Old 10-15-2009, 01:30 AM
95z28camaro's Avatar
Default Nitrous on stock/bolton only motor record?
Does anybody know what the record for a stock motor/bolt-on only LT1 camaro on nitrous is? I have a new SR 383 motor being built for next season so not worried about this one. I have a couple of racer friends that have enough parts to put together a complete nitrous system and we are thinkin about sprayin the hell out of it. Or i could just sell it and take the couple hundred bucks for the complete motor... Couple hundred bucks or setting a new nitrous only record?!?
Old 10-15-2009, 01:49 AM
gregrob's Avatar
Tune a 200 shot right on race gas and I could see low 10's / high 9's.
Old 10-15-2009, 01:56 AM
you really think 9s are possible if it held up and all other went right?! that would be amazing! I was just going to be happy to see mid 10's lol. Do you know what the record for stock internals on nitrous is as of now tho?
Old 10-15-2009, 01:59 AM
Also im not about to pay to have it tuned... ill run 104 thru it but thats about the just of what i would do. We are going to set it up to pull fuel from the regulator also to make it be like a wet kit. somethin just quick and simple. its either sell it or blow it up going for gold!!! lol
Old 10-15-2009, 04:28 AM
gregrob's Avatar
I dont know what the record is but yes with the times in your sig I dont see why at least very low 10's wouldn't be possible.
You better have some way of pulling timing...
Old 10-15-2009, 07:07 AM
86formula's Avatar
no i dont think 9s are possible, you would need more then bolt ons and a 200 shot
Old 10-15-2009, 07:15 AM
gregrob's Avatar
Stock eliminator cars run low 10's on motor, it could be done w a 200 shot.
Old 10-15-2009, 07:50 AM
Ill see if i can find someone that has a msd timing control i can temporarily use to hook up to my MSD 6AL-2. Think my boss has one.
Old 10-15-2009, 09:09 AM
fergymoto's Avatar
https://ls1tech.com/forums/lt1-lt4-m...na-9s-n2o.html
Old 10-15-2009, 09:43 AM
pyro719's Avatar
Checkout the nitrous section of cz28.com There a guy on there named Andy K. And He ran 10.80's with stock exhuast manifolds
Old 10-15-2009, 09:58 AM
T/ALT1's Avatar
A stock longblock LT1 is not going to run 10's on n2o unless the car is under 3000lbs and can 60' 1.3's or so. But it can run 10's without too many problems. Goodluck Clint
Old 10-15-2009, 10:01 AM
86formula's Avatar
i didnt say a heads/cam car with N2O couldnt do it, i said a bolt on car with N2O couldnt
Old 10-15-2009, 10:07 AM
fergymoto's Avatar
My bad, I misread and thought you said stock bottom end being the only stipulation.
Old 10-15-2009, 10:09 AM
RamAir95TA's Avatar
Set the record, blow it up, then someone else will come along and beat it. Then you're left in second place with a blown motor. Yay!
Old 10-15-2009, 10:36 AM
pyro719's Avatar
Stock LT1 goes 10.89 http://www.camaroz28.com/forums/show...ighlight=stock
Old 10-15-2009, 12:15 PM
robsquikz28's Avatar
a stock bottom end with a 200 shot you do not need race gas for that.
I have seen up to 250 at a single shot on the stock bottom end and it did hold up.
Old 10-15-2009, 12:41 PM
lifeisgood's Avatar
lmao yup yup yup
Old 10-15-2009, 12:43 PM
BSmiff's Avatar
What were your supporting mods to handle this type of spray? And do you think a stock 4l60e would hold up or would I need to wait until I get a built trans/converter/cooler?
Old 10-15-2009, 01:20 PM
importben's Avatar
was wondering the same. how much nitrous i could run with just intake, exhaust, and 1.6 rocker arms and a tune.. with 93. no race gas.
Old 10-15-2009, 03:00 PM
pyro719's Avatar
150 shot for sure, 200 if your brave. Id run some race gas with the 200 though and some br7ef spark plugs and pull a little extra timing. Ill be running a 200 shot and some TFS 21* heads with my little hotcam next year.
Quick Reply: Nitrous on stock/bolton only motor record?
