96 LT1 A4 no power at take off!!!!!!
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Also, check your Trans Fluid. I had the same problem with my stall. It felt like we weren't moving till we hit 3k RPMS. Added trans fluid and what do you know, miracle. Kinda sucks cause I'm not sure if there is a way of telling how much fluid you have in there. I know when i looked at the stick, there was fluid on it but not alot. But lesson learned none the less. Good luck with your problem! Hope you figure it out!
before you start throwing money at and guessing, do some testing first. i suggest going through and reading shoeboxs website. has a ton of info on the LT1 f-bodies on troubleshooting, how to's, locations of stuff etc....
http://www.shbox.com/1/4th_gen_tech1.html
