A/C Delete
Old Oct 18, 2009 | 08:46 PM
Black96transam's Avatar
well i was gonna do the bmr k-member and put the pinto rack and pinion.. which will delete the whole power steering setup.. then the thought of my girlfriend driving kicked in too.. and i was like ehh.. im trying to find someone who has that setup and see what they say
Old Oct 18, 2009 | 08:59 PM
litch2004's Avatar
well if you are running skinnies it isnt that big of a deal. Running full size tires isnt that bad once you are moving. At a stop it is a lot more difficult. My old 69 chevelle wasnt bad at all until you were stopped then it took a little bit of muscle.
Old Oct 18, 2009 | 09:04 PM
yeah the drag car i had was easy on a roll.. but you know how females are.. they say the pinto rack's ratio was set up good so it wasn't hard..
Old Oct 18, 2009 | 09:54 PM
the_merv's Avatar
Veteran: Air Force
Here is mine..
Old Oct 18, 2009 | 10:05 PM
Nice...
Old Oct 18, 2009 | 10:20 PM
Black94Z28's Avatar
Im running complete HVAC delete plus power steering delete, here are some pictures from my build thread...
Old Oct 18, 2009 | 10:54 PM
litch2004's Avatar
i went ahead and removed everything including controls because it all was broke anyways
Old Oct 18, 2009 | 10:56 PM
everything works on mine fine
Old Nov 6, 2009 | 10:06 AM
ls1adamls1's Avatar
i got a question about doing this. i have already gotten rid of my ac compressor and condesor, but i want to get the stuff off the fire wall also.
i know they have a delete plate you put on after you remove the ac box but can i leave the heater core? and will it still work when i remove the ac crap?
how hard is it to remove the ac box?
Old Nov 6, 2009 | 10:42 AM
RamAir95TA's Avatar
Check this thread. Some REALLY good pictures.
https://ls1tech.com/forums/lt1-lt4-m...e-today-5.html
Additionally, instead of the "tunnel" made into the plate, you can also cut out the plastic between the blower motor and the vents, essentially making a passage between the two so your heat still functions.
Old Nov 6, 2009 | 10:55 AM
ls1adamls1's Avatar
i dont want to take the stuff from under the dash just the stuff from under the hood.
Old Nov 6, 2009 | 11:14 AM
  #32
RamAir95TA's Avatar
I haven't done this yet, so I'm not sure if you can cut the box in half without accessing it from the interior side. I would imagine that it would be MUCH easier.
Old Nov 6, 2009 | 11:22 AM
  #33
bombebomb's Avatar
Hot in the summer without the AC but its worth it for the weight reduction lol. Plus I like cruising with the windows down so I can hear the car.
Old Nov 6, 2009 | 11:32 AM
  #34
ls1adamls1's Avatar
yeah i never use the ac so i got rid of it.
but is it possible to just remove the box from under the hood? it looks like the merv did it in the pics above so maybe he can chime in here.
Old Nov 7, 2009 | 01:42 AM
  #35
the_merv's Avatar
Veteran: Air Force
Ya mine still has the Heat.
Here are some pics..
I also got rid of the stock Metal lines..
Old Nov 7, 2009 | 03:02 AM
  #36
ls1adamls1's Avatar
ok so in the circle you cut some platic or metal out and created your own passage for the blower right? also did you pull the unit out with the engine in the car or is it even possible?
Old Nov 7, 2009 | 10:02 AM
  #37
the_merv's Avatar
Veteran: Air Force
That is so the Blower Motor can blow into the Heater Core.
Old Nov 7, 2009 | 10:33 AM
  #38
ls1adamls1's Avatar
did you make the plate or did you buy it? the only company that i found that makes a delete panel is bmr.
Old Nov 7, 2009 | 03:00 PM
  #39
the_merv's Avatar
Veteran: Air Force
I made mine out of some Aluminum..
Old Nov 7, 2009 | 03:22 PM
  #40
litch2004's Avatar
pcmforless also makes them. but both are going to made to install front the inside with everything gutted. there will need to be some modification needed to retain the heater and to mount plate on the outside.
