383 stock heads decent size cam
I cam across a local forged 383 short block for a good price. My question is can I run it with stock lt1 heads with the cam that's in it and it be daily drivable. Would it make decent power till I can get the heads ported?
Cam specs are
New Comp Cam 230/236 @.050 .576 .571 lift w/ 1.6 rockers
Maybe its a silly question but I always heard people saying stuff about heads not providing enough for a 383. Its just till I can get LE to port em but I still gotta get trans built and a moser 9inch. And this is my daily driver so need dependable and decent driveability.
Thanks
Cam specs are
Thanks
Cam specs are
Thanks
Cam specs are
Thanks
That combo won't make the best power, but it will be streetable as long as you have a good stall.
The next thing after putting that in would be get my 4l60e rebuilt with a good stall prob 3600. What will happen with the setup with stock stall?
If I get it, it doesn't have to go in. I could hang on to it till I get the stall and rear end and ported heads. Just wondered if I could use it till I get the rest of the car fixed.
Yes you could run that bottom end with untouched heads and and that cam and it be fine for a DD. Once you save up for heads that's where the real power will come from.
About the converter...your car will drive poorly without a larger stall converter when running a cam such as that. It will pull on the brakes at lights, may buck a bit, and you will lose brake vacumn. Not at all ideal for a DD, did it before because I was not educated enough about stalls and cams but driving the car was a real PITA.
If it were me I would buy a stall and a cam and see how you like it with the stock bottom end. Maybe toss some heads on there when money allows and have yourself a nice 11 second car. When that gets boring move onto the big cubes, just IMO.
I am running stock unported heads with a bigger cam than that. Drives fine, stock torque converter also.
In short, I am driving exactly what you are buying lol. Ill even throw in some track times just to add to the info.
12.21 @ 114 (I hit 115mph once that night, but not that run)
which would you go for with a 383 with a 6- rod strocker Wiseco Forged Pistons or je forged pistons i think dont get me wrong the je's are more for spraying right? sorry for going off topic
His is not on stock springs(if it is than it wont be for long lol) and neither is mine.
Both companies make pistons that are built for spraying. Wieseco's would be fine, JE's are just more for assurance/top of the food chain quality. If you do not plan on spraying thats even more of a reason not to buy the top brand of pistons (JE/ROSS).
I could get the parts to support the heads for no problems, it is my DD I'm not gonna risk anything.
Is the stall gonna be that big a deal? After I got this setup in, I will save for a performabuilt trans with a 3200-3600 stall. The forged 383 with the decent size cam is 1700. I thought good deal has scat forged and forged srp pistons.
Maybe I should just wait and get forged 355 built. Can get forged scat setup for 1300 plus machine work and assembly. 200 for LE cam
What do you mean by "that big of a deal"?
If you mean will it make it slower on the track, than yes it will.
If you are asking if it will make it undrivable, than no I drive mine around all the time with stock stall.
Mine was drivable and I drove it all over but it sure as hell wasn't DD worthy or comfortable. Nothing like having shitty brakes and having to put the car in neutral at every light so it would stop pulling on the brakes. Go for it, it may work out for you or may drive like complete **** like mine did. Then you will be banging your head against the wall because it's your daily. Been there done that. Do some searching, camming a car before installing stall is a poor mistake unless your talking a tiny cam which you aren't. If you wanna take the risk go for it but for every one person that said there car drove ok without a stall there are ten saying otherwise.
Thanks
Personally I wouldn't cam it without throwing in a stall, but there are some that say that the added torque from a stroker will make your stock converter stall a little bit higher so you could get away with a 383 with a baby cam and a stock stall but that cam you have is a pretty good size and may require a little bit of stall even with the stroker just my .02
