1.6rr on stock cam
To tell u guys the truth i have no idea what i am doing just started reading up on all this, this morning but i also had no idea what i was doing when i blew the head gaskets on my other camaro now the thing runs better then before after taking it apart and putting it back together.
Stock studs are 3/8", so if you don't plan on converting to a non self-aligning setup, all you need are the rockers, springs, and hardware. While a non self-aligning setup is much stabler, if you don't plan on camming anytime soon and pushing the RPMs too far, a self-aligning setup is fine.
You do NOT need hardened pushrods for a SA rocker setup.
As for all this "hardware" you'll need, the LT4 springs use the same retainers, cups, and locks as the LT1. So just swap the springs and you're good to go no need to buy anything else.
