emissions
Old Apr 29, 2010 | 07:39 AM
  #41
95TransAm_ToM's Avatar
Originally Posted by tom falco
In CT if all but 2 monitors are set it passes 96-2000.One monitor not set 2001-DATE. It makes no difference where you took the car the test is the same. Is the ses light working on the dash? Does the ecm have a stored code or pending code. If not how did the test station know the tuner tuned out the rear O2 sensors. TOM FALCO CT certified emission inspector. CT is a visual emission state. If the cats are gone you get a fail. Some testers dont look and some do. The inspector is not required to test data output of sensors. If he did that he is in violation of the law. But he can fail you on visual check NO CATS. By the way why would you remove cats ??? They dont reduce HP. In some cases it increases HP. TOM
Well tom.... i put $3700 in tuning + exaust to pass the great state of CT emissions and i still failed. I have cats and brand new O2s, but my car will not pass th sniff test.
