Operation Engine Bay of Pigs
Old Jan 21, 2010 | 01:09 PM
  #61
robsquikz28's Avatar
When you get the map sensor attached lmk and keep up the good work!!! where you at in chicago?
Old Jan 21, 2010 | 08:03 PM
  #62
Torque Fiend's Avatar
avondale neighborhood near logan square in the northwest side of the city.
Old Jan 21, 2010 | 10:01 PM
  #63
update 1/21/2010
I got that little bitch of a plug on the passenger side head.
That's all I did today, it didn't take my dad too long, but whatever.
Took the rotozip to it and resquared the "hole" but bigger for the 3/8" extension to fit and drilled a hole through it to that the plug could retain the heat from the torch and thus come off. Thank god for the "old man" and all our "old men" out there.
  #64
Cool, I have a few buds that live in that area. I might see ya one day!
Old Jan 22, 2010 | 12:13 PM
  #65
LS1 SPEED's Avatar
I have to say it is looking great. This is going to be a nice DD man!
Old Jan 24, 2010 | 02:45 PM
  #66
Thanks man, your engine bay was a big inspiration.
Update for today: 1/24/2010
Took the L-Bracket that I found at Home Deport and did some measuring and lining up w/ a caliper and T- Square.
Test fitting the first holes to mount the bracket on the back of the IM where the EGR goes. Holes lined up pretty well, not perfect but it'll work, nice and tight.
After a whole lot of measuring and screwing up, and redrilling and whatnot I finally got it done and mounted the map sensor.
wing nuts probably won't stay, but I need longer screws/bolts because I'm currently using the factory ones.
Old Jan 24, 2010 | 02:50 PM
  #67
Should I paint the bracket or no?
If I paint it it'll be low gloss black.
Old Jan 24, 2010 | 03:13 PM
  #68
LS1 SPEED's Avatar
nice to hear I was a part of your build
I say std. nuts over the wing nits and sating black on the bracket. I wish I would have done the vac. port and MAP relocate when I did mine, but I'm not pulling it back apart now....no leaks are nice for a junk LT1
Old Jan 24, 2010 | 04:13 PM
  #69
scj's Avatar
scj
paint the bracket!
Old Jan 24, 2010 | 04:16 PM
  #70
greendrazil's Avatar
Yeah, Paint it.
Old Jan 24, 2010 | 04:18 PM
  #71
kmracer's Avatar
Originally Posted by vtec
im ok with everything except replacing stock fuel lines with stainless braided. thats an expensive option that is less reliable and heavier than the stock stuff. less reliable not because of the hose itself, but you will now have several hose ends that could fail or just come unscrewed.
you're not very bright.
i think NHRA should mandate all top fuel cars to use plastic fuel lines with GM quick disconnect fittings.
reading a comment like that, i dont know how you managed to build a 9 second car...
Old Jan 24, 2010 | 04:22 PM
  #72
HAha, just what I thought when I read that too. This is a great build!
Old Jan 24, 2010 | 07:48 PM
  #73
awwww ****!
edit: Alright currently in the process of painting it. I just laid the 1st coat of primer.
Old Jan 24, 2010 | 09:22 PM
  #74
Bingo exactly what I was thinking and need to do!!! MY car is junk
Old Jan 24, 2010 | 09:24 PM
  #75
What are you planning on doing with the harness connector for the map sensor and then are you just goin to connect a small hose from the back of the port the maps sensor port?
Old Jan 24, 2010 | 11:04 PM
  #76
yes just run a hose from vac port to the map. The wiring will just be routed to the back. It already runs that way just isolate the wires for it and run as neatly as possible.
Old Jan 24, 2010 | 11:11 PM
  #77
You had seen previously that I painted my valve covers red. Well I messed that paint job up, and didn't let it cure properly.
Well, I said **** it and just redid the whole job.
Base gloss black coat.
Vinyl applied
It's really difficult to get nice looking because of the waves in our valve covers. That's why I want to buy the flat surface valve covers on my signature, I just can't afford to pay 100 for them right now. I'll redo them when I can afford them, maybe even powdercoat.
All my pics of the vcs are pretty crappy, that lighting sucks.
Clear over the stickers.
Originally the base coat was red and then I was supposed to apply the stickers paid black over the stickers and then peel them off, but since it's hard to lay the stickers properly it's pretty hard to get the right paint w/o it creeping into the tiny gaps btn the stickers and weird angles.
Old Jan 24, 2010 | 11:25 PM
  #78
lOOKING VERY NICE bling bling
Old Jan 25, 2010 | 12:56 AM
  #79
iceman15's Avatar
Dude if I bought you a airplane ticket and all the beer you want would you be willing to do my engine bay cleanup?!?! lol jk but yours is looking great!
Old Jan 25, 2010 | 01:28 AM
  #80
skinnies's Avatar
Looking good!
