Operation Engine Bay of Pigs
#101
yeah its all good keep on keepin on lol youll get there... my car will be dead for a while especially with the wire mod and fuel line mod... have to decide on what to do with my fuse relay box
#106
#107
1/4/10
Today was a pain in the ***. I decided not to do the fuel lines but rather do the wiring first. Didn't get very far.
It was a headache trying to tuck the wires under the fuel rail and then bolting the POS down. The back driver side screw/hole wouldn't line up.
Finally got it but I'm still not too sure on the injectors being put in the holes properly for injectors 5 and 7. See picture, it's sticking out too high, but would go down when I pushed down on it.
Anyway here's the mess:
Drilled holes for zip ties to hold the bundle of wires up high and tight to the cowl to reduce its visibility.
Covered the holes w/ RTV so water won't drop through.
Barely visible now
Tucked the damn injector wires and cleaned up the exposed wire at the back of the rail as best as possible.
****Also see how injectors 5and7 seem way too highVVVVVVVVVVVVV
Tackling this mess tomorrow, cutting, splicing, adding wire, soldering, etc tomorrow.
Barely visible now
#110
Alright, WTF?!
I'm trying to finish this damn car up, but I can't for the life of me get the passenger header back on.
When I first did my headers I put the passenger on w/o having to remove the motor mount, but now I can't fit it in with it on. My AC lines are not even on the car now, like they were then and I can't even fit them through.
So, I decided to take the motor mount bolt off, I did, lifted the engine, and it went threw. Now I can't get the proper angle to mate the header w/ the head and be flush (or parallel).
I'm so frustrated.
I'm so frustrated.
#111
Alright, WTF?!
I'm so frustrated.
I'm so frustrated.
#113
Final Update? 3/3/2010
So, I'm pretty much finished but I've run into a bunch of little small problems, mainly fuel leaks from the lines. It's the first time I've ever done AN fittings, so I'm working on it. I think I finally got it done, but I still need to run the car for several minutes, and take it out on another test drive.
Here are the pics that I didn't bother posting up while I was working on the car. It's been a long tedious job this past month.
I actually decided to get rid of the AC, after my dad broke the box in the engine bay during torquing of the heads. Oh well.
Rerouting wires underneath the engine to create the clean bare look up top.
Bare wires, cut and lengthened, soldered and covered with heat shrink.
Covered the wires in Flame Retardant braided sleeving.
Fuel lines routed and ziptied in place.
#117
EDIT: I just need to tuck my wires
#118
The fuel line looks great!!! Although leaks suck I am sure you got them sorted out...
If you don't mind me asking how much did it cost to build that fuel line setup?
Thanks
Matt
Thanks
Matt
#119
around 130 that's using teflon hose not rubber.
That includes the an fittings and the fuel line adapters for this particular GM application.
Got 15ft of SS line from Ebay.
