Which connecting rods and pistons
my friend is giving me a lt1 block for free. and im thinking of rebuilding it and adding forged internals.. which rods are good ? i was thinking of some manley sportsmans rods.. how good are they/ and maybe some je pistons.. Im trying to do a stout Nitrous set up with a pretty high compression
i have used the pro-comp rods in a build before..
i used the procomp 5140 rods in a older 350 engine rebuild... the build was a mild setup.. stock cast crankshaft, procomp 5140 rods, forged flattops, the old camel hump heads, 1.94 and 1.5 undercut stailess valves, .468/,488 cam.. small cam to use with a tunnel ram... rotating assembly balanced..
i know i wount be real hard on this engine as its going into an old hotrod/weekend cruiser so i'm not to concerned about revving this engine very high. setting it up to shift at like 5500 rpm.. the tunnel ram is mainly for looks..
i can say that i was impressed with the procomp electronics 5140 rods, i was expecting some cheap ***, cheap looking rods, and i wasnt really concerned about it.. when they come in i was suprised at the finish and fit, they were dimensionaly correct, near ideal clearances, and had arp cap screw rod bolts.. i had some pictures of them, i'll post them if i can find them.
i wouldnt use them on a blown or nitrous setup though..
a shot of my engine, pay no attention to the truck in the background.. thats my old beater
any vendors that we have as far as lt1 with good reasonable pricing?>im thinking about going either scat or manley and as far as pistons je pistons or diamond....
+1 for compstar. They make really good stuff and they are reasonably priced. Some of the vendors on here carry it (I know AI does for sure). Or you can check out www.callies.com for more information on the parts they offer.
