Roller Rockers
Old Jan 17, 2010 | 08:54 PM
J-13gtp's Avatar
Default Roller Rockers
Been looking at buying a set of roller rockers for awhile and I got a question about a certain brand.
Are ARP pro roller rockers any good, also what size are the stock rockers on the lt1s? I just cant seem to remember.
Old Jan 17, 2010 | 09:03 PM
yonerhottlt1's Avatar
I know that the stock rockers have a 1.5 ratio so if your going to upgrade make sure you get some 1.6's. Not sure about the ARP ones tho but you will also need valvesprings if you do the rockers as they will produce more lift outta your cam.
Old Jan 17, 2010 | 09:30 PM
TravisMcGill2000's Avatar
I run stock springs with my 1.6 rr. I also have a set i would sell. Pm me if interested
Old Jan 17, 2010 | 09:57 PM
robsquikz28's Avatar
They are fine but im sure you can find some cheaper ones as in pricing in the for sale ads.
Old Jan 18, 2010 | 12:17 AM
J-13gtp's Avatar
Thanks for the reply guys. I do still have one more question. Whats the stud size on the stock roller rockers and will 3/8 stud work in its place?
Old Jan 18, 2010 | 12:46 AM
RamAir95TA's Avatar
Stock stud size is 3/8", so upgrade to 7/16"!
Old Jan 18, 2010 | 05:05 AM
gregrob's Avatar
I like the comp Ultra Pro Magnums. Check them out.
You get what you pay for!
Old Jan 18, 2010 | 12:16 PM
J-13gtp's Avatar
So will the 7/16 go right in or would there be some modification to the heads in order to make them work?
Old Jan 18, 2010 | 12:21 PM
RamAir95TA's Avatar
No modifications needed. Remove the old studs, install the new ones.
Old Jan 18, 2010 | 12:29 PM
J-13gtp's Avatar
Cool, thanks guys for the reply's.
Old Jan 19, 2010 | 07:42 AM
TheDon619's Avatar
the new studs screw in, you dont need to upgrade valvesprings to run 1.6s, id go comp pro mags theyll last for ever.
Old Jan 19, 2010 | 10:17 AM
RamAir95TA's Avatar
You NEED to upgrade valvesprings when switching to 1.6 rockers. The stock springs will be dangerously close to coil bind. Not worth the risk.
Old Jan 19, 2010 | 10:20 AM
ThreeHonks's Avatar
Old Jan 20, 2010 | 03:28 AM
J-13gtp's Avatar
Planning on getting a good set of springs. Possible a set from patriot. But right now I'm looking for a good set of push rods. Any suggestions?
Old Jan 20, 2010 | 03:42 AM
gregrob's Avatar
Trickflows are the only way to go IMO. You can pay a lot more for another brand, but the TF's work great and are reasonable. Around 80 bucks IIRC
Old Jan 20, 2010 | 04:32 AM
suicidal racing's Avatar
what are the stock springs good for when it comes to max lift..also most dont factor in valve lash..if i got a cam that gives me .480 lift with a 1.5 rocker..dont mean im running that.its more around .455 once lash gets factored in..
Old Jan 20, 2010 | 04:39 AM
the_merv's Avatar
Veteran: Air Force
How much Valve Lash are you running? Judging by what you say if you think about it your Rockers have no preload, and are loose.
Besides..Lift is Lift, with the proper Preload there is no lash that will take away .02-.03 of an inch.
Unless I'm reading what you said wrong it makes no sense to me..
Old Jan 20, 2010 | 09:00 AM
69gto96z's Avatar
That's a risky thing to do, I spent hours looking into springs when I was thinking about making the jump to 1.6's with my factory cam, and everything I ever read said to upgrade atleast LT4 springs.
Old Jan 20, 2010 | 10:07 AM
TheDon619's Avatar
i ran 1.6s on my stock springs for 20k miles and drive the **** out of it with no problem except i over reved the SAs so NSA went on for another 10k.
Old Jan 20, 2010 | 11:20 AM
97camaross's Avatar
how are you guys replacing the springs with the heads in the car. like I know how to do it but I was just wondering if there it a trick or certian tool.
