Ls1 t56 ???
Old Jan 24, 2010 | 05:41 PM
JB_97ws6TA's Avatar
Default Ls1 t56 ???
Can you install an LS1 T56 with LS1 bellhousing, LS1 clutch (hydraulics, slave, etc) in an LT1 car? If not please be specific as to why...flywheel, bellhousing spacing, etc. I found a T56 out of an LS car and like there slave cylinder setup much better than the clutch fork and it is a helluva deal so I would like to know if I can use it. Thanks
Old Jan 24, 2010 | 05:47 PM
black_byrdWS6's Avatar
I wanted to know the exact opposite!! I wanted to find out if i can use my 6speed out of my LT1 for a ls1 thanks not trying to ***** OPs thread
Old Jan 24, 2010 | 05:49 PM
tbird31's Avatar
pretty sure the input shafts are different. i know for sure that the LS1 and LT1 bellhousings are different though. something about hydraulics as well...
Old Jan 24, 2010 | 05:50 PM
JB_97ws6TA's Avatar
Well both of our question should be answered and if it turn out that it can't be done...I'll trade ya
Old Jan 24, 2010 | 05:52 PM
JB_97ws6TA's Avatar
I know the hydraulics are different and the bellhousing on an LS has one more mounting bolt but other than that are there any real differences?
Old Jan 24, 2010 | 05:58 PM
ya for sure just let me know
Old Jan 24, 2010 | 06:21 PM
yonerhottlt1's Avatar
They have different input shafts and the bell housings are different. Not sure what else is different but to answer your question(s) it wont work. Good luck......
Old Jan 24, 2010 | 07:37 PM
BlueRamAir's Avatar
The input shafts are interchangeable, but its a lot of work IMHO.
Old Jan 24, 2010 | 08:11 PM
gregrob's Avatar
Its certainly not a lot of work, takes about 10mins to swap them.
You need a different bell housing, input shaft, and you have to keep the lt1 clutch setup.
Old Jan 24, 2010 | 08:16 PM
gregrob's Avatar
https://ls1tech.com/forums/manual-tr...-pictures.html
Old Jan 24, 2010 | 08:24 PM
BlueRamAir's Avatar
I didn't say time wise. To do all the work + $ to put an LS1 T-56 in. Yeah its a lot. If you had both trans sitting in front of you out of the car well than its a no brainer. I should have been more specific.
Old Jan 24, 2010 | 08:25 PM
gregrob's Avatar
Gotcha
Old Jan 30, 2010 | 04:44 PM
95CamaroLS1's Avatar
Im putting an LS1 engine/T-56 into my 95 Z28 camaro and i got the tranny all done. We took the LT1 T-56 and mated it to the LS1 engine. All we had to do was input shaft, mid plate, bellhousing, slave cylinder, and i think that was pretty much it? We took it to a local transmission shop to put it all together and reseal it.
Old Jan 30, 2010 | 04:54 PM
the_merv's Avatar
Veteran: Air Force
I hope you guys are checking the end-play on the Input Shaft and Counter Shaft when you are switchin out the Front Plates and Input Shafts..you would be suprised what a couple of thousanths can do..
Old Jan 30, 2010 | 06:24 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
merv is very correct about the end play. you need a shim kit if you start swapping stuff
next you need a clutch, lt flywheel ls pr. plate assembly.
as mentioned a mid plate and also a 0.500" between the trans and b/h.
you need to modify your trans mount as well, and your trans tunnel, if i recall correctly.
have fun! if you don't buy it would you pm me if it is really that good of a deal.
taner's Avatar
Old Jan 31, 2010 | 02:35 AM
the_merv's Avatar
Veteran: Air Force
Actually the Tranny Mount location is the same..the Case & Tailshaft is identical between the two, the difference is the Front Plate & Bell Housing. No need to modify anything on the Tranny Tunnel either, these cars are identical from 93-02.
If he is going to be using an LS1 K-member, which I highly suggest, then the LS1 & T56 will line up in stock location without a problem..mine lines up perfect.
The best way here instead of all the shimming and crap is to just swap units..one of the guys is looking for a LT1 T56, the other guy is looking for a LS1 T56 so just swap..lol
