Oil pump question
I wouldn't add any extra, the oil sloshing around the reciprocating assembly isn't good
If you go with the HV pump, be prepared to periodically remove the intake and inspect the drive gear. I don't know of how many threads I have read where people were shocked at what they saw. Of course, some had loss of pressure because of a shredded gear.
If your builder sets up your bearing clearances so HV pump is of designed benefit, fine.
I have a 383 with the HV (builder set bearing clearances for one) and a stock pan.....don't subscribe to the "it will pump the pan dry" concept....
I did have my intake off 10k miles after build...no "visable" sign of drive gear wear nor has there ever been metal shavings in the oil.
I respect opinions by shbox so I can not discount is notes....just in my case I have not experienced drive gear wear or noticed the pan getting sucked dry...at least OP not indicateing that happened.
