Rebuilt transmission install
Old Feb 5, 2010 | 06:50 AM
dwoodwo1's Avatar
Default Rebuilt transmission install
Hey all,
I am looking to buy a '95 z28, and I have a budget of max $2500 to get a reasonably running car. I have found one listed that I could likely get for below $1000, but the transmission will not go into reverse. Would it be worth my time and money to buy this thing cheap and have a rebuilt manual transmission installed (i.e. how much would that cost), or should I just wait on another deal?
I debated on whether to put this in the whats it worth section, so I apologize if this needs to be moved.
Thanks
Old Feb 5, 2010 | 10:33 AM
the_merv's Avatar
Veteran: Air Force
T56 or Auto..?
Old Feb 5, 2010 | 10:37 AM
cgroh89's Avatar
Depends on a4/m6 And if it is a m6 cost can get driven up alot depending what is all tore up in the trans.
You can find junkyard a4's cheap to just get it going
Old Feb 5, 2010 | 10:54 AM
dwoodwo1's Avatar
Sorry I did not clarify - I was planning to either have them rebuild the T56 or find another one in good enough shape to just have it installed.
Old Feb 5, 2010 | 10:56 AM
the_merv's Avatar
Veteran: Air Force
Tear into it yourself..Reverse is an easy fix.
Old Feb 5, 2010 | 11:01 AM
dwoodwo1's Avatar
I suppose i could lol.... gotta buy some equipment to actually get it out of there though. I think the wife would hit me with the sledgehammer if I came home one day with a cherry picker and a hoist.
Old Feb 5, 2010 | 11:12 AM
the_merv's Avatar
Veteran: Air Force
Simple tools, a 24" extension, and a couple of Ramps and you can get it out..
Get some friends and Beer, and it goes alot quicker.
Old Feb 5, 2010 | 11:19 AM
StealthFormula's Avatar
The key is having the car as high in the air as possible and some long *** extensions, 24"+. I recommend using a tranny jack to get the trans back in but if you have some nice pieces of wood sitting around you could put them on a floor jack and make it work. With the above covered you will be good to go.
Old Feb 5, 2010 | 11:30 AM
dwoodwo1's Avatar
My bad I was under the impression the motor had to come out to pull the tranny. Shows how much I know about this stuff. Anyway I have some buddies who are a bit more knowledgeable about this stuff, I will see if they wanna help. Sounds like a fun project.
Old Feb 5, 2010 | 11:31 AM
prostreet67's Avatar
just dont roll through the beams, you wont need reverse! j/k easy fix do it yourself youll be happy with it.
Old Feb 5, 2010 | 11:56 AM
RamAir95TA's Avatar
+1 on the trans jack. You can rent them for a few bucks and they are well worth it.
I didn't have one for my trans install though. I put my trans up on blocks and lowered the car onto it via the lift. Piece of cake!
Old Feb 5, 2010 | 05:31 PM
nik1703's Avatar
naaah, just take it out with your bare hands! that's what i did last time. it's only 100 pounds or something. no problemo
Old Feb 5, 2010 | 05:38 PM
Barney Z's Avatar
Same here. Jack would have been easier. . . . but, chest works too! Just a lil more worrysome. . . lol
Old Feb 5, 2010 | 05:39 PM
nik1703's Avatar
no worries if you are a manly man!
Old Feb 5, 2010 | 06:01 PM
whytryz28's Avatar
I had no problem benching my auto up into place, so a manual should be easier.
Old Feb 8, 2010 | 08:25 AM
dwoodwo1's Avatar
Thanks for all of the replies... now if the seller would just get back to me with some more info. I would love to get the ball rolling on this.
