What is this part??? (with pictures)
The alternator pulley is a smaller pulley to make the alternator spin faster, is called an overdrive pulley, and I had to run one on mine. The battery died while idling at the track b/f I installed it, so I put it on and it was all good. All stock electrics, btw.
When I had the UD pulley and no OD pulley, I used NAPA part number 25-060598, which NAPA says is 60.4"
When I put the OD pulley on the alternator, I used DAYCO part number 5060590, which is a 59" belt.
And yes, you're probably right, it looks like a March pulley. I use to run one myself.
