93 z28 camaro problems
http://shbox.com/1/dlc2.jpg
Blink - Pause - blink - blink - Pause = a code 12.
it will display code 12 twice, letiing you it ready, then it will blink all the stored codes, when it blinks a 12 again there are no more codes and it will begin cycling through the codes again. (it's a bit of a pain, but if you don't have any someone to read the codes with a scanner it does work.)
Pretty common on the 93 is a bad air pump, Acutally the wire to the pump on the 93s burn up, there was a TSB for this long ago to replace the wire with a heavier gauge ( I think it is the white wire from the fuse box under the hood to the pump). You can also unplug the air pump and see if you still get the check engine problem, on the 93s if you disconnect/delete the pump they don't throw codes, only when it's hooked up? The error thrown by a bad pump comes up as a quad drive error = code 26.
Also rememeber to reset the ECM by pulling the fuse or disconnecting the battery or even if you fix you the probem the code will still show up.
