Ahh Missing bolts! Rocker Question!
Old Mar 7, 2010 | 12:30 PM
boostedpower's Avatar
Slack in the timing chain yeah is a considerable amount (I have said the same thing to myself! maybe thats why it keeps getting gas in the exhaust?), this is how it was when i took it apart, this motor was all sorts of fucked, and as for this rocker flat part thing what is everyone talking about? thank you for the people who are actually supporting my build!
Old Mar 7, 2010 | 12:32 PM
Ohhhh I see never mind about the rocker... just needed someone to explain it better the part in the middle of the rocker! taking it off and turning it now thank you guys!!!
Old Mar 7, 2010 | 12:34 PM
SS RRR's Avatar
Village Troll
Originally Posted by Z28Camaro30Ann
If you didnt line up the dots your timing will be WAY off and you will kiss your valves on the pistons...this will bend the valves, possibly damage the valve seals, damage your pistons, and possibly damage the block and/or heads...
The position is fine. Before the timing chain goes on you can spin the cam gear one way and the crank another several times over, line up the dots and it will still be at TDC on #6.
OP- You need to do some homework before doing this again, or at least have someone w/ you who knows what they're doing. It seems you know enough to get yourself in trouble, but when you are to the point of "just want this project to be over..." you could be on the way to making careless and costly mistakes. Do yourself a favor and pick up some "how to build a small block chevy" books like these two:
I'm sure any good bookstore will have them. You'll be amazed at what you can learn.
Old Mar 7, 2010 | 12:35 PM
kierstyn's Avatar
Like everyone else has said take that rocker back off and the center of it will twist over. Theres a flat side and a rounded side if you put the flat side up like its supposed to be it will give you the threads needed to put the polylock on.
Old Mar 7, 2010 | 12:36 PM
So does anyone know the thread pattern and length to the motor mount bolts?
Old Mar 7, 2010 | 12:37 PM
I got it thanks! sorry for the brain fart!
Old Mar 7, 2010 | 12:38 PM
bigj2717's Avatar
Yeah the middle part there's a flat side and a rounded side all the flats need to be up. If I were you I would for sure replace that timing chain while you're in there and since one stud is broke if their stock, which I assume they are, get a set of arp studs. Their less the $40 from summit and you never have to worry about them
Old Mar 7, 2010 | 12:42 PM
Which stud do you guys see is broken? a head stud?!?!
Old Mar 7, 2010 | 12:46 PM
bigj2717's Avatar
No you don't have head studs. It looks like that rocker stud is broken
Old Mar 7, 2010 | 12:49 PM
SS RRR's Avatar
Village Troll
It doesn't look broken. It looks distorted from possibly a set screw being torqued on it a little too much. The slack in the timing chain is completely normal for a link bar style chain(what you have).
Old Mar 7, 2010 | 12:50 PM
the cam and push rods were in that valve was on "open" i turned that middle part to flat, lock went right on, no issues
Old Mar 7, 2010 | 12:59 PM
  #32
I was going to leave the spider cage off so i could run oil through the block, but since everyone is freaking out I just put it on for pics lol
Old Mar 7, 2010 | 01:09 PM
  #33
I looked over the studs, and I thought they look okay?! here are some pics that might better clear everything up.... I hope..... ---->
pretty pic... lolz..... ---->
Old Mar 7, 2010 | 01:13 PM
  #34
SS RRR's Avatar
Village Troll
Be prepared to catch more **** for your unsanitary working conditions. Make doubly sure when you button the top back up you get all that crap off the heads and oil valley.
Old Mar 7, 2010 | 01:18 PM
  #35
Yeah well no lift, forgetting newspaper, and just being generally unorganized has destroyed my garage, but its coming along slowly but surely with the help of everyone (I'm pressure washing and coating the garage floor after)
Old Mar 7, 2010 | 02:21 PM
  #36
So am i Good to tighten the rockers down? all studs are okay?
Old Mar 7, 2010 | 02:27 PM
  #37
RamAir95TA's Avatar
That motor is going to blow the **** up.
Do you even know what valve lash is?
Old Mar 7, 2010 | 02:39 PM
  #38
bigj2717's Avatar
Yeah you look fine to put the rockers on just make sure you adjust them all properly Shoebox's site will be your friend http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old Mar 7, 2010 | 02:40 PM
  #39
old93camaro's Avatar
lmfo.... I can't wait to hear this run
Old Mar 7, 2010 | 02:42 PM
  #40
Z28Camaro30Ann's Avatar
X2!!! Holy hell dude, pay attention! Valve Lash HAS to be set! If you tighten them down without doing it PROPERLY you will **** EVERYTHING up! Seriously dude! You say everyone needs to calm down but you are missing BASIC steps! You are about to put it back togetherwrong and spend thousnads because you are going to trash your engine!
Also, are those STOCK pushrods? What lift are your springs and what lifters did you use? You DO know you HAVE to measure pushrod length right??? If you dont, that could be ALMOST as bad as setting lash incorrectly!
Next, Is the plug for your Oil Pressure Sensor STILL in the sensor?? If it is you REALLY need to get that harness fixed BEFORE you start this engine! Otherwise you wont know what Oil Pressure you have and after a build like that OP is CRUCIAL! It will tell you if anything is wrong before everything blows up!
Another thing, just a word of advice, dont lay poly locks and small objects inside your lifter valley! It could EASILY fall down into the engine and **** you life up.
And did you lose your motor mount bolts too?? Did you ever find your Crank Hub Bolt?
