Ahh Missing bolts! Rocker Question!
To check pushrod length take off 1 rocker...take a black marker and color in the top of the valve stem until it is solid black. Put your rocker back on and set the lash on it. Turn your crank a few times. The rocker will wear a pattern into the marker on the top of the valve stem as it moves This is called a witness mark. If the pushrod length is correct, the witness mark should be located on the inboard third of the valve-stem tip. If the witness mark is too close to the intake side of the valve-stem tip, the pushrod is too short. If the witness mark is in the middle or toward the exhaust side of the valve-stem tip, then the pushrod is too long.
Adjust the INTAKE valve when the EXHAUST valve begins to OPEN!
DO NOT SPIN the pushrod...if you tighten it until you cant spin it they will be TOO TIGHT!
Loosen the rocker and grab the back of it where it sits on the valve. Move it up and down. You should hear a clicking sound of the rocker hitting the valve stem. Tighten the poly until the MOMENT the clicking cant be heard any more. Once you get to that point you will be at ZERO LASH. From there turn the poly 1/2 turn to a full turn to set it. I went 3/4 turn to be safe. Once you have done that use the wrench to HOLD YOUR POLY LOCK STILL, and take your allen wrench and tighten the set screw
EXH INT INT EXH EXH INT INT EXH
Left would be the front of the engine, right would be the back. As I set a vlalve I would put a checkmark next to that valve on my paper so I knew it was set. Then I would keep turning the crank until the other valve for that cylinder was ready, then I would set its lash, put a check nect to it and cross off that cylinder from my paper. Then I would start on the next cylinder.
Yes you turn the crank alot doing this, BUT you dont get lose or mixed up.
boostedpower, just adjust each valve when the lifter is on the base circle (i.e. when you turn the crank and the lifter doesn't move). Spin the pushrod until you barely begin to feel drag, then add your preload. Tighten the **** out of the set screw. Done.
It should be noted that on a higher HP build where valve lash tolerances are much tighter that people do not like the "pushrod-spin-drag" method and opt for a different method.
Here straight off Shoebox's site that it seem like you are refusing to read#
Method 3
Another cylinder by cylinder method that does not require looking at the balancer position, follows:
(A remote starter switch is quite helpful)
# Turn the engine in the normal direction of rotation until the exhaust lifter for the cylinder you are adjusting starts to move up (valve begins to open).
# On the intake rocker arm, adjust for zero lash and add your desired preload.
# Turn the engine over again until the intake lifter on the same cylinder comes all the way up (valve open) and then goes almost all the way back down (valve almost closed) .
# Now, adjust the rocker arm for the exhaust valve on that cylinder to zero lash and add your desired preload.
Continue the above procedure for each cylinder until all valves are adjusted to the same amount of preload. This procedure will work for any hydraulic lifter cam with adjustable rocker arms. Refer to this diagram posted above if you need visual reference. The reason I specify lifter movement in the above is because when you start off with completely loose rockers, there is no valve movement to watch.
Poly Locks
Here is something additional for those that use "poly locks" (typically used with roller rockers).
Since the poly lock is not a prevailing torque fastener like the nut used with the stock rocker and ball arrangement, it spins freely on the rocker stud. This gives you an advantage to finding zero lash. With the allen lock backed off, spin down the nut until it just stops. This is very close, if not right on zero lash in most cases. Check your pushrod for proper movement and play with it to get a feeling just how snug or loose the nut should be to obtain zero lash. Once you do that, you can just use the nut to reach zero lash and not have to worry about messing with the troublesome pushrod. This will speed up your valve adjustment.
Another aide is to make a mark on the top of the nut so that you can easily see how far you have turned the nut. I always found it a little difficult to obtain the exact amount of rotation on the nuts under the cowl, because of there being less room to swing a ratchet or other tool handle. I used a little dab of white paint on the top and was easily able to tell when I made a half turn or whatever was needed. Now, I can just use a wrench to tighten the nuts, then throw the allen wrench on it and snug the set screw down (while holding the nut).
Some like to run the allen set screw down and then tighten it and the nut together. If you overdo it this way, you may break the nut. I always have good luck with setting the nut and then the set screw (never had one come loose). With all the variables in making adjustments to hydraulic lifters like the number of turns for preload, methods of finding zero lash and trying to see what you are doing under the cowl, slight errors are common. Just try to be as consistent as possible and use the method that works best for you.
this is getting good
