whats rods and pistons you 355 guys runing
Why don't you try one of the other FOUR threads you've started in the past 3 days?
https://ls1tech.com/forums/lt1-lt4-m...heads-cam.html
https://ls1tech.com/forums/lt1-lt4-m...ons-355-a.html
https://ls1tech.com/forums/lt1-lt4-m...-355-help.html
http://ltxtech.com/forums/showthread...build-N-A-rods
You have to put together a power number in your head that you want it to make and then someone can tell you. This is just apples to mangos. you can use a stock crank and rods as well as any number of pistons to make 500hp on. One thing determines the power you are going to make in the bottom end but it also depends if you want to use boost. The piston will make up part of the power equation, but the heads and fuel delivery really make the power. Parts in the bottom end just need to support the type of top end power package you are going to use. What do you want it to do?
manley h beams
je 11cc domed pistons
