Mcleod street twin!!
I installed mine and it was PITA. I would have paid somebody who has done it before if I had it over again. If i remember I had to buy a different slave cylinder to get it to work properly. In my opinion , If you are not making over 650rwhp it is overkill and many clutch guys will tell you the same but if ou are anything like me might as well get it done right the 1st time.
One trick that I've heard is when you have the trans most of the way in, slip the t/o bearing fork on and bolt up the slave cylinder and get in the car and push the clutch in. It will disengage the clutch and allow everything to line up and go in smoothly.
Just wish I knew about this when I did my install
