11.04 @ 122 - Stupid LT1!!
I'm so close to 10s...it's driving me nuts.
Went to Cecil County Raceway in MD tonight. Had good air (about 60-degrees at the time of the two runs I did make before getting booted for no cage) and okay track prep.
Two days ago, I finished the install of my Wolfe rear solid swaybar, which, IMO, is hands down the best suspension modification a drag racer could do. When properly adjusted, the car leaves straight as an arrow. Before, I had alot of left-hand pull while the car meandered down the track. That's a thing of the past. 60's tonight were 1.54 and 1.57 (best to date is a 1.52) respectively, spinning just a bit each time.
Someone else filmed the 11.04 run, so I'll post the vid of that once it's available. Here's a video of the second run of the night, an 11.11.![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
http://www.youtube.com/watch?v=x2cizjJ-qGY
For those that don't know, the car is an AI heads/cam/383 + bolt-ons through a 4L60E and Ford 9". Still untuned and still under-geared.
I already have the Wolfe roll cage - just need to have it installed.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Mine did that, I was stuck at 11.02 for a few trips.
I have a 4.10 with a 28 tire, it goes through the trpas at about 6700-6900 depending on da.
I would go a 4.30 with a 28 tall tire.
Keep pickin at it, GET A DAMN TUNE.....quit messin around. You spent all that money on the car, spend $500 and get a tune.
Once he's in the area though, I'll have him take care of it.
very nice results
why race the car untuned?
I would not say a 3.90/26' tire is way under geared. The converter is most important with an auto IMO v's a gear. I run a 3.73/28" tire and as most most know my car runs hard. 1.38 60ft , 126 mph and approx 6600 out the back door. I was going to make a gear swap last year, but after talking to a few knowlegable friends/racers and Yank it would not be work it.
I'm sure a 4.10-4.30 with a 28" tire would pick you up some. I would get the tune and try a 28" tire before making a gear swap. I would also monitor shift extension and consult with your converter guy before a gear change.
again congrats at cracking away at that 10 sec mark
Because there aren't many places around here that are reputable with LT1s. Bryan @ PCMforless seems to have the knack the most, and he only comes out to the NJ area once every few weeks. I missed the last time he was out because of a few bugs with the car.
Once he's in the area though, I'll have him take care of it.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
