Tunerpro RT V5 Beta - All in 1 datalogger / tuner
Well I got this up and working guys. To clarify yes it DOES work with LT1's....
No more need to pay for datamaster, or put up with freescans hard to read and clunky interface anymore!
Tunerpro RT V5 is the answer. It's a fully customizable datalogging and tuning solution ALL IN ONE and it's free! Donate if you like is $30 and will remove the 10 sec startup delay screen.
Here's a screen shot of a custom dash board I created to use when tuning. There are some other much cooler ones out there, but this is my first attempt and displays all the data I need for tuning. The built in scaling and display functions are better than Tunercats IMO and I haven't found anything yet that Tunerpro cant do that TC can. If I run across it I can use TC for that one thing, but so far I plan on using Tunerpro from now on.
I'll post a few screen shots actually so you can see some of the new features of V5...
Forgive the quality, uploading them to FB degrades it quite a bit, rest assured the program looks great in person, no fuzzy or hard to read labels, etc...
![](https://photos-a.ak.fbcdn.net/hphotos-ak-snc3/hs490.snc3/26773_373343177337_572657337_3742357_525633_n.jpg)
Instead of attaching them all, here's the link to my FB album:
http://www.facebook.com/photo.php?pi...7&id=572657337
Looks like a pretty good deal. I like the screens you made. what cable are u using? moates or akm?
Will that program work on a vista and Windows 7 machine?
thanks
thanks
Pretty nice, I remember using an earlier version of TunerPro and it wasn't nearly as polished as this looks. Does this include a graph like Datamaster does after a datalogging run so you can chart different parameters?
please forgive my ignorance, but i dont know anything about tuning, can someone please edumacate me
what is this program?? where can i get it?? what do i need to be able to use it?? what can i do with it?? etc, etc
Also, will this work on 92-93 LT1s? Mine is OBDI, but it uses an EPROM. I know it's different from 94+ in the fact that it uses a chip, but I don't know exactly how all this works.
You will also need to read thru the site and find if your vehicle is supported. If so, you will also need a communication cable with one end on it that works with your particular aldl port on your vehicle. You will also need what is called a "definition file" which is a file that has information on it pertaining to your vehicle's computer. Best thing for you to do is contact Mark Mansur at tunerpro and have him tell you what you will need. But first, if I were you, I'd go to this site, and do some serious reading before attempting to tune your car.
http://para.noid.org/~lj/
click on PCM tutorial on the left side of the screen at the bottom of the column
