EFI 24X LS1 pcm conversion
I'm not a tuner, I admittedly don't know all the fine details about it. I was just trying to point out that these features were available in the LS1 pcm and that they are supposed to offer advantages for tuning boosted motors. Maybe the extended/added tables aren't beneficial, I don't know, it's been years since I researched into PCM options for a boosted setup and I remember everyone being pretty excited when that stuff came out for the LS1 pcm. I have a rudimentary understanding of the resolution of the tables on a stock LT1 pcm from a customer's standpoint, but not enough to warrant trying to explain it as it relates to real-world tuning and if it offers any tangible limitations/benefits.
You need to have the 96-97 style timing cover to run the conversion. I assume you still have it on the car, considering it's a 97. You can run a double roller either by having your timing cover machined for clearance, or buy a billet piece from EFI Connection. Why do you need a double roller anyway? It's overkill.
This could be true with the better ignition, with the coil on plug setup but again like I stated above. 722 RWHP unusable on the street?? If you saw my car you would of thought it was a bone stock Z. I drove that car daily, on 400 mile round trip "With AC" Yes you need stickies to hook on the street, but other than that You would of loved the looks on the faces of the people driving Z06's and Vipers on the highway when I just pulled away
Bottom line, like I said, I see people with mild builds and others telling them they "Need" the conversion when that is not a true statement...
My car is a street car with A/C...and I could always use more power
I don't NEED to drink beer every day. I don't NEED to even own a car.
I did the conversion because it makes things easier and less complicated, and more dependable. I didn't NEED to. I WANTED to, and benefit and peace of mind was had from doing so.
Like I said I am still waiting to see someone with a setup and like I said with no other changes other than the conversion, How much did they gain...
I am doing just this conversion next month nothing else added but the conversion I will let u know the results once its installed and tuned later next month
