LT1 Opti SUCKS!!!!!!!!!!!
Old Mar 30, 2010 | 07:43 PM
1994 TA's Avatar
Default LT1 Opti SUCKS!!!!!!!!!!!
This opti system has to be the worst setup in the world. I cannot get the balancer off!!! Anyone run into that problem??? I am ready to push the car out for the garbage truck. Any pointers on how to change the opti without having a stroke??
Old Mar 30, 2010 | 07:46 PM
weaklt1's Avatar
don't you have a pulley puller? if its rusty and stuck spray some blaster on there. it is not that bad.good luck.
Old Mar 30, 2010 | 07:47 PM
1994 TA's Avatar
I have one but now I have to get different bolts. The ones that came with the puller are the wrong size.
Old Mar 30, 2010 | 07:48 PM
somlt1's Avatar
you can get a puller but i have always used a brass hammer and just hit it till it falls off dont hit it to hard so that the edge of the pulley doesnt chip
Old Mar 30, 2010 | 07:49 PM
1994 TA's Avatar
How do you hit it? From the back or on the edge? I am open to anything.
Old Mar 30, 2010 | 07:59 PM
1badzee's Avatar
You're ignorant as hell to say the Opti Spark setup is the worst in the world because you have Down's Syndrome and can't get the balancer off.. Good luck none the less.
Old Mar 30, 2010 | 08:01 PM
BOLO's Avatar
Actually, I never had to remove the balancer to replace the optispark. The water pump was the only thing on the way. Patience is the virtue, my friend.
Old Mar 30, 2010 | 08:15 PM
z_speedfreak's Avatar
beat me to it!
Old Mar 30, 2010 | 08:19 PM
airfix's Avatar
Useless....
Old Mar 30, 2010 | 08:20 PM
1994 TA's Avatar
"So you are saying there is a chance" is there a specific way to do that or just be careful?
Old Mar 30, 2010 | 08:21 PM
TWS's Avatar
TWS
I have Down's syndrome, ADD, and a little man complex, but I just get the right pulley puller and they come right off. Put some axle grease on the crank snout before you put it back on.
Rebuild the opti with an MSD kit or just get an MSD opti. Some people even bitch about the MSD, but mine has been great. Just put red loctite on the rotor screws before you install.
And yes, you can swap it with the damper on, but for me it's been a bitch to line it up when the damper is there.
Old Mar 30, 2010 | 08:23 PM
1994 TA's Avatar
Did I insult you personally? Did you design this setup?
Old Mar 30, 2010 | 08:27 PM
FASTFATBOY's Avatar
You dont have the pull the balancer to get the opti off DUHHHHHHHHHHH
Pull the ring, leave the hub. 3 bolts I'm a thinkin.
Old Mar 30, 2010 | 08:29 PM
Sabaktes's Avatar
Quit being a baby.
Old Mar 30, 2010 | 08:31 PM
1994 TA's Avatar
I have the 3 bolts out and you are saying that there is a ring also? I do not know anything about these cars. So I am trying to learn.
Old Mar 30, 2010 | 08:36 PM
FASTFATBOY's Avatar
Take the three bolts out, tap the outer ring of the balancer and it will come off. The center part will stay mounted.
Old Mar 30, 2010 | 08:40 PM
FASTFATBOY's Avatar
Google IS yo freind
http://www.fierolt1.com/lt1_95_up_OptiReplace.htm
http://www.firebirdnation.com/forums...?showtopic=608
Old Mar 30, 2010 | 08:42 PM
1994 TA's Avatar
Thanks for the help.
Old Mar 30, 2010 | 11:19 PM
RamAir95TA's Avatar
You're probably using the wrong puller. A standard 3-JAW puller works just fine.
Old Mar 30, 2010 | 11:48 PM
jay7199's Avatar
if you have a autozone hub puller the bolts they provide are wrong, what you can do is get 3 nuts you might have around the house ( i did ) put the bolt threw the hole and a nut on the back side. should pop right off
