Ss lt1 (super slow)
I have a 1997 trans am lt1, bone stock ex for k&n cold air.
When i get in the car in the morning (engine cold ) and let it run for a min or 2 and take off the car is a beast, It wont hook in first for crap and just runs good. After a 15-20 min drive the lt1 jumps out and a 2.0L takes its place. It is a huge notice in power loss. It wont even chirp the tires on takeoff and gets a hesitation. If you put the car in P and rev it, it has hesi. everytime you hit it and it doesnt matter where in the rpm band it is.
Also when i got the car (about 2 months ago) it didnt have a MAF
some dumb sh*t pulled it off. But the car ran great with no maf??? It actually felt like it slowed the car down when i put a new one on. I have also put a new TPS and a temp sensor for the puter (fans no work).
Sorry for the long post and the spelling
How does the car run when you remove the maf?
If they are working now but, weren't before, There may have been some damage done to internal parts from it running super hot in the past?.. PLUS, it sounds like someone had been tinkering and beating on it prior to you so, could be alot of things. Anything leaking? Burning oil at all? Any really bad tapping knocking that you can hear under load?
Im not beating on the car when it is 30 out side. It has been warm 70-80 and i let it run for a few min and just off idle there is a diff.
The car runs good no smoke 45lbs of oil pressure when warm, but leaks oil pretty good. I bought the car from a good friend but he didnt have it long. I dont know the person before him so......
Also if you spent the time to SD tune it wouldnt you lower the fan temps? They kick on at 225 and off at 190-210ish. Temps stay at 170 going down the road.
