What alternator relocation are you guy's using?
Thanks in advance
Ryan
Good luck
http://www.jegs.com/webapp/wcs/store...Term=555-50542
notice the bracket is the same as in everyones kit..nice mark up huh!
Now like the ebay link you will need that part # belt..thanks blackz93 for that link i been trying to figure out the part number for some time on the belt all these kits use.
Okay now that you have everything run down to your local ace hardware,lowes or home depot and grab the bolts you will need a quck mock up and measure will give you an idea of the bolt lengths you need..now that you got you bolts that will work walk over to the plumbing section and get a foot of copper pipe lil bit larger then your bolts..this is what you will use to make your spacers..gab some washers for your bolts also while your at it..
Now just take your bracket and mount your alt up to the block..look and make sure everything is inline and then measure up and cut the copper tube around that lenght..then take that and put a washer on each end and bam your spacer are now made and your done..take car out for a spin and enjoy the savings
i look at the mark up on the ls1 and lt1 **** and just shake my head seeing alot of it is same **** used on first gen sbc or bbc's
That isnt the bracket we use. It will not fit the LT1 alt.
