calling all you high mileage cam guys
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
i'm on the fence of doing a cam swap. more than likely the cc503. the problems i'm facing is 170,000 mile stock bottom end w/ a 170,000 mile 4l60e. this is my DD so i'm worried i'll destroy the bottom end and have to do the work twice.
should i go for it or save my money and rebuild it later?
words of advice be it good or bad are welcome!
if the NO's win then i will be getting BMR lowering springs.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Ask yourself
1. The way I drive how many miles do I expect a rebuilt engine to last?
2. How long will 170,000 motor last if I baby it?
3. Am I willing to baby it?
4. When can I afford to build the engine and transmission to last for my driving?
Good luck
Good luck
if you have a stock motor and trans with 170k in your DD you should have some money aside as a safety net because murphy's law owns you
you don't wanna have your motor or trans take a crap, get fired from your job because you can't get to work all because you blew your money on a cam swap that does nothing at this point and might've helped put the car back on the road.
i would like to have another car to DD. but if i buy a $1000 pos then i'll be putting money in it as well just to keep it running.
the motor is still in good shape, i.e. not burning/using oil.
i talked to lloyd elliott and he told me that if it hasn't run hot and been regularly maintained then it shouldn't be a problem.
it's not gonna be spinning much higher than stock.
yes i am willing to drive it easy because i drive it easy now.
170,000 miles dd modded LT1 your gonna be in debt so fast its not even funny. **** breaks. People always forget about the 10 bolt, you mod the LT1, you can kiss your 10 bolt goodbye. Get another cheapo dd so when your F body is down you have something else to get to work in.
I have 236k on my engine, but have a rebuilt tranny and rear. I have comtemplated doing a cam, but my only reason for not doing so is that I feel the cam bearings wear more so on lt1's than a sbc That would be my only concern. I guess that you could do the front bearing, as I feel this takes most the abuse of driving the opti also. But at 170k if you have good oil pressure, good compression, I would go for it.
tia
andy schuck
tia
andy schuck
