high compression
Old Apr 22, 2010 | 09:50 PM
6801's Avatar
Default high compression
anyone running 11.8-12.1 compression on the street without any problemes of detnation.
Old Apr 22, 2010 | 09:55 PM
RamAir95TA's Avatar
Static compression doesn't determine "streetability" or "probability of detonation." That's the job of the dynamic compression ratio which incorporates camshaft valve events paralleled with static compression dimensions.
For what it's worth, I'm running 12.6:1 static, 9.6:1 dynamic on 93 octane with 0 KR.
Old Apr 22, 2010 | 09:58 PM
aboatguy's Avatar
RamAir95TA is correct....
I'm running 12.1:1 SCR and no issues with pump gas
Old Apr 22, 2010 | 10:42 PM
86formula's Avatar
12.2 SCR here
Old Apr 22, 2010 | 10:49 PM
Matts94Z28's Avatar
No problems here... I assume I am close with stock deck height, 11.1 flat tops w -5cc reliefs and impala gaskets. If anyone wants to calculate that up be my guest!
Old Apr 22, 2010 | 10:57 PM
suicidal racing's Avatar
i ran 13-1 on one of my old motors..from 93 to 114 was 5-7 degree diff in timing.
Old Apr 22, 2010 | 11:39 PM
SexyTransAm's Avatar
not my lt1 but my 80TA with a gen 1 SBC i run 13:1 on the street with 93 pump gas
Old Apr 23, 2010 | 02:56 AM
gregrob's Avatar
11.16 with 54cc chamber heads...
Old Apr 23, 2010 | 09:20 AM
Matts94Z28's Avatar
Ha! Not close. Guess I can go with the .026 gaskets when I do heads.
Old Apr 23, 2010 | 10:43 AM
Colin91Z's Avatar
I run 11.8:1 on 91 octane, with zero Knock retard.
Old Apr 23, 2010 | 01:12 PM
bombebomb's Avatar
13:1 on a carbed? engine, with normal flowing heads? Seems way high for that.
With that being said, 12:1 93 here.
Old Apr 23, 2010 | 05:50 PM
yes a carb sbc. yea norm coolent flowing heads. but the car runs fine at 13:1 on 93 pump gas. but its a very small street friendly cam. iv had the timing up to 36 and no knocking. and plugs come out looking great! oh and i have a very good cooling system!
Old Apr 23, 2010 | 09:30 PM
6801's Avatar
good deal with a -5 flat top and 54cc heads and gasket i was told ill be at 12.1 on a 383 how long after inital start up should i wait too get it dyno tuned im afraid to drive and im putting a 3500 chip in the msd if i drive it
Old Apr 24, 2010 | 12:35 AM
Wicked94Z's Avatar
oh it has a small cam? that explains it all...
Old Apr 24, 2010 | 01:00 AM
86formula's Avatar
you have to seat the rings, mine is being broken in on the dyno
Old Apr 24, 2010 | 01:48 AM
gregrob's Avatar
Lol...
Old Apr 24, 2010 | 01:51 AM
yea u know one of thoes 3/4 race cam not the full race cam. that would be too much
