thermostat
Old May 5, 2010 | 07:56 PM
schram1124's Avatar
Default thermostat
what thermostat should i go with 96 trans am 5,7 m6 mods in sig and also going with a elc wp csr
Old May 5, 2010 | 08:55 PM
305 h.o.'s Avatar
Order a 160 thermostat from summit or jegs. Car wont run over 175ish while in clean air.
Old May 5, 2010 | 10:15 PM
RamAir95TA's Avatar
Yeah, wrong. The thermostat itself won't make the car run cooler (at least not for an extended period of time). You need earlier fan activation via PCM programming and/or a manual fan switch to fully take advantage of the thermostat.
Old May 6, 2010 | 09:12 PM
305 h.o.'s Avatar
When I installed my thermostat the car went from running 195 in clean air to around 175. So it does work. It only rises in heavy traffic or at a red light.
Old May 6, 2010 | 09:19 PM
RamAir95TA's Avatar
The thermostat alone cannot cause the car to run 20 degrees cooler. All it does is delay how long it takes for the car to warm up. It is used in conjunction with earlier fan programming (which I see you have a tune from Ion).
Old May 6, 2010 | 09:30 PM
bigj2717's Avatar
Ramair95 is right. The thermostat wont make that big of a difference unless you have the fans come on with it to lower the temp of the coolant
Old May 6, 2010 | 09:45 PM
defaultexistence's Avatar
X3.......
Old May 6, 2010 | 09:50 PM
SexyTransAm's Avatar
get a 160 and find a used hypertech for cheap and tune the fans
Old May 6, 2010 | 09:58 PM
jaycenk's Avatar
Time for some headers and a tune. Tune all the crap out you don't need and power tune as well as like ramair said get those fans to turn on sooner. My 383 runs right at 195 on a hot day no A/C with fans tuned low and a 160deg thermo.
Old May 7, 2010 | 01:50 AM
MasterTomos's Avatar
do the 160 degree stat now, and tune for it later. simple as that
