fuel pressure questions
You could have a leaky injector or the FPR could be bad. Pull the vacuum line off the regulator and look for fuel out the back with the system primed and/or running. A leaky injector is also easy to diagnose - pull up the fuel rails with the injectors still attached and prime the fuel system. Any leaky injectors will drip fuel.
I also second the motion that you check for a leaky injector (s) as yet another possible problem source.
Another way to check for a leaky injector is pull the fuel rail with injectors still atached out of the intake and presureize the system with all of the injecotrs still in the rail. If you have one stuck open it will spray.
What kind of FP regulator did you replace your stock one with? Did you pull the vac line to make sure it holds at 43 to 46psi? I would run the car with the fuel pressure gage hooked up and cap the vac line that runs to the regulator and see if it holds good pressure.
Check your voltage at the pump wire harness to make sure you keep good voltage there while the pump runs. Another is to make sure you got the feed line from the pump hooked up right inside the tank.
well i dont have access to a scanner right now, but i have a guage that is hooked up all the time and it just fluctuates pressure all the time. i just ordered new injectors so hopefully that is the problem. but i just replaced the regulator with another stock regulator that i had laying around the shop so it is possible that it was bad too. would there be a benifit to upgrad to an adjustable regulator even if i just keep stock pressure?
If the regulator is set at 40psi static (no vaccuum line connected) and you have 20 psi vacuum (line connected) you will only see 20 on your gage which is exactly what it is supposed to be.
With the vacuum compensation line disconnected, with 41-47psi at idle is an acceptable range with 43.5psi being spot-on (what the injectors are rated at). Reattach the vacuum line, and the pressure will drop proportional to intake manifold vacuum. A 3-10psi drop below the "no vacuum" pressure is normal for a stock cam.
At no point should the fuel pressure drop below ~32psi.
