URGENT! 97 Camaro z28 helppppp in the middle of the work!
so im working in changing the water pump drive seal.
so i get to the water pump and the bearing on the water pump are no good no more!
i taken the water pump to kragen and to another local auto store. they all told me that they dont know what the bearing part called.
so i cant change it.
what is it called so i dont want to buy a whole new water pump when mine is still good.
also on the very last picture down the page is that the water pump drive seal?
this is the bearing where do i get it helppp
i need to change this bearing what is it called
is this the water pump drive seal?
<a href="http://photobucket.com" target="_blank"><img src="http://i249.photobucket.com/albums/gg223/DAYAYBOI510/waterpump2.jpg" border="0" alt="Photobucket"></a>
Like said above, buy a new pump. I did disasemble my pump before to powder coat the housing so it is possible to get gut it. I had to press the shaft apart and I did get the bearing out as well as the seal. It was tedious and I had to guess at things when pressing it back together. I got lucky and it works fine plus it looks great powder coated.
Need a new pump or turn that into an electric pump. Also that is not the w/p drive seal. The seal is on the timing cover itself, not the back of the pump. You need a screw driver or chisel to pop the one out of the timing cover and then a socket or something to drive the new one on over the splined shaft.
(ask me how I know this....)
One other thing, there is a "groove" on one end the OD of the WP drive shaft. The groove goes at the engine side of the shaft.
