GM race shop block
#403
Since I kind of feel bad for semi-hijacking this thread lets talk about what you guys are all upset about with no big bore blocks.
What is it exactly that keeps you guys working on the LT1 platform. Is it the reverse cooling? In reality all this platform is is a Gen 1 engine with backwards cooling. Most bitch about the opti, or the computer. Why not do a Gen 1? You would have infinite parts availability, infinate bore/stroke possiblilites...no "dreaded" opti. They are both 23° heads which in the real world suck....lifter placements are all the same, bore space is the same, engine mounts are the same....bells are the same.
Why beat your head against the wall???
#404
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Mind you, we were up til 3am in the parking lot of a hotel cleaning up the entire contents of my oil pan off the asphalt while drinking margaritas!!!
#405
Cool....The troopers name is Carl....I remember when he pulled up and got out. Asking for "Jacob, I am looking for Jacob"......I was crapping my pants....![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
we all started doing little bolt on parts and before you know it, we end up having something that is out of control.
#407
#409
Go here: http://www.top-et.com/impalass/
Click on "detail" next to entry #5. That's all I know.
I saw this car run several times back in its day. I think Sam was driving it.
Maybe ramair96 can provide more ??
Dave Horn was the driver Sam was the main wrench and I did the entire electrical and track computer tuning. The trans am I have now is the result of that car.
#411
Limited bore size on the LT block. I noticed that your bore size on your 402 is 4.130". The LT1 MAY be able to do 4.04" on an ideal block without compromising busting into a water jacket. Your bore size would uncork some of the excellent head choices used by some here. Especially Tony Sheppard who is running AFR 235's and is already in the 8's. Or even those who have run SB2.2's.
#412
That car would do burnout for days. One time we were testin gon the street , dumb i know.., We were chased by the cops in that car
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#413
Right, I get that is the point, but why stick with the LTX platform at all? If bore size is that important to you, why not go to a Gen 1 platform?
That is the point I am getting at, the LTX doesn't really vary from the Gen 1 in many ways. Cooling, and front mounted opti, are about it.
#414
#415
#417
They also make front mount distributors and crank triggers.....if the big bore really was a big deal you could make it work.
And as far as the "added" compression ratio. What HP difference would you expect to see between 1 click of compression over the potential of 50 cubic inches?
I am not trying to get into a nasty argument, just looking at this "logically"......what benefit is there to staying with the LTX platform?
#418
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#419
#420
Mikey has run a 10.06 in 88 degree heat with high humidity. A hurricane was breathing down on us. He runs a 4L60E and those aren't too well known for their 1/4 mile times.
