383 short block project with LE2 top end.***Now running***Jan. 2011
For about 2 weeks I've been searching here for infos and I found too many set up possible so now I'm confused.
Here's what I do with my car 1st . :
1994 LT1 T56
- I drive my car only on sunny days to cruise around town , I may hit the 1/4 mile a few times a year . I want this thing to be very drivable & reliable to cruise around town.
Lloyd Elliot suggested me his LE2 package with a ported intake and a camshaft with 223/230 .565/.565 112 LSA . ( bought it already May 2010 )
I will not spray or use any type of supercharger and I want a nice flat "torque" power for street use.
I want to get a rotating assembly to be able to put together a 383 CI that will be machined here locally .
I've heard "cast" , "nodular" "forged" crankshaft and I've heard rods that need to works with "regular base circle" camshaft ( what ever it means ) .
I'd like to know what you guys will suggest me for
-: Crankshaft .
-: Pistons ( with dish or not ) and brand .
-: rods that will work with "regular base circle" camshaft ( if it means something )
-: Oil pump ?
-Misc stuff I may forget.
I had the impression I was going to be able to figure that out myself but so many choices and options.
I'd like to spend around $1500.00 on the rotating assembly if possible.
I'm not building a race car , just a small car to have fun around town so please don't go too crazy with your suggestions. ( $$$ ) .
Thanks in advance for your help and knowledge.
Update July 13 2010
( 2010 Setup , now on motor stand just in case of emergency )
-GM LT1 5.7 Litre. 355CI Bore 0.030".
-JE SRP Forged Pistons (10.3:1 compression).
-Manley Sportsman Forged Rods.
-GM hotcam Kit (hotcam, LT4 springs, 1.6 Roller Rocker).
-Aluminum heads.
-Hedman 69640 Headers .
-MSD Ignition.
-CSR Electric Water pump.
-Ford Taurus V6 3.8L electric fan conversion.
***Work in progress*** : ( Updated March 7th 2011 )
Lloyd Elliot LE2 package. www.Elliottsportworks.com
-Fully Ported heads milled 0.030" with 0.56cc chamber, casting 10128374.
Manley 2.00/1.56 6000 series valves.
PAC 1218 bee hive springs (145 lbs seat and 340 lbs open)
Steel retainers and locks.
205 cc intake port flow about 275/190 CFM.
-12.05:1 Comp. Ratio , 230PSI Compression.
-CompCams Pro-Magnum Roller rocker 1.6:1 7/16" studs "NSF" (None Self Aligned).
-850-16 CompCams Hi-energy hydrolic roller lifter.
-7937-16 CompCams Hi-Tech Pushrods 5/16"X7.050".
-MR-1896 Sealed Power 5/16" Guide Plate.
-Fully ported Intake manifold casting 12552138.
-AS&M 58mm Throttle body.
-Ford Racing SVO 30 Lbs. Injectors.
-Custom camshaft 223/230 .565/.565 112 LSA .
-Fel Pro 1074 head gaskets .039".
-Fel Pro 1284 intake gaskets.
-Autolite #104 0.030".
-Hypertech 160 degree thermostat.
-MSD 83811 Pro-Billet Distributor.
-MSD 8226 Blaster coil.
-MSD 32149 8.5mm Spark plug wires.
-TPIS High flow mass air sensor housing.
-Meziere WP118HD Electric Water Pump.
-Holley 255lph fuel pump.
-Hedman 69640 modified for Fastburn "d" style GM exhaust port to 2.5" into 3" N1 Pipe to Magnaflow Muffler.
-Shortblock :
-385CI ( 6.3L ) LT1 4 Bolt main Corvette shortblock.
-Scat 9000 stroked lightweight forged crank.
-Scat forged rods.
-Mallory Forged Pistons -5cc.
-4045MS-15 .040" + .005" Mahle rings file to fit.
-Rings gap : 1st .018" , 2nd .020".
-ARP main studs.
-Melling 10555 High Volume Oil pump.
-Clevite 77 MS-909H STD bearings crank Bearings.
-Clevite 77 CB-663H STD Connecting rods bearings.
-12370835 GM single roller extreme duty timing chain set.
-Fluidampr Harmonic balancer # 740101.
-Balanced and Blueprinted.
-Cleaned, decked, bored .040 over and honed with deck plates, new frost plugs, etc.
-Transmision T56 6 Speed.
-Fidnanza #12 flywheel.
-SPEC 3 Pressure plate & Centerforce clutch disk.
-Pro 5.0 Short throw shifter.
-Abbott Electronic speedo converter.
Differential limited slip 4.10.
1994 LT1 T56
-: Crankshaft .
-: Oil pump ?
Update July 13 2010
-Aluminum heads.
-MSD Ignition.
-Shortblock :
-Scat forged rods.
-ARP main studs.
2K is ok for me also.
See we have two reply and already we have 2 different opinion.
Do I really have to go with forged crankshaft or cast "Nodular" what ever the difference is , will do the trick ? I don't think I'll be over 400 425 RWHP with my 383 LE2 setup and the restricted exhaust & headers I'm running right now.
Keep the comments comming , I'll pick what I think is OK for me.
This is a good debate and can be good for other members with a similar project too .
This is the other things I'm running.
Eagle 3.8 Crank
Eagle H-beam 6" Rods
Wiseco Pro Tru 4.030" -13cc Pistons
You will want to use a 3.75 crank to get you 383 and make sure its forged and pick your brand.
Here is some pictures of them
http://i20.photobucket.com/albums/b2...3/PIC-0155.jpg
http://i20.photobucket.com/albums/b2...3/PIC-0156.jpg
http://i20.photobucket.com/albums/b2...3/PIC-0157.jpg
well my setup is from clayton racing engines and i paid 1780 shipped for my scat rotating assembly. all forged with 5 cc dished pistons and the arp 2000 rod bolt upgrade with all the bearings i needed. i also use the meling select pump. i was inforrmed by clayton racing that this setup would support 750-1000hp and i belive 8000 rpms. i think you could get the same setup minus the rod bolts for 1700 and it would support up to 700 i think. this is the only setup i have used but i love it with my le2 heads and custom cam. it would be overkill for ur setup. but 200 extra dollars might be worth while in this case. i hope this helps, if you have any questions feel free to pm me.
the tune is the most important part. i am running 12.5 to 1 compression on 91 octane but i have a little more cam than you. i think around 12 to 1 would be a good setup. which i think you can get that with a 10 cc dish and a thin head gasket. others need to chime in on that tho. my heads were milled .030 thousands the get 12.5 to one on my 5 cc dished pistions.
To find out of its even remotely right I would make sure it didn't have a mechanical fuel pump boss and the 4 water pump holes on the front of the block are two easy ways to weed out a bunch of blocks. Then get him to tell you some part numbers off the block. Shoebox had good pics of all of the locations.
Still haven't bought anything for the short block yet but here's what piston's specification I was suggested to buy :
Something with a negative piston pin ( what ever it means ) with preferred -10cc dish or -16cc .
I'm unable to locate some -10cc pistons but -16cc is pretty commond.
What you guys think of this :
Forged 383 racing rotating assembly for LT1 LT4 and all late 1 piece seal blocks
SCAT Forged 3.750 stroke crankshaft
SCAT Forged 6" H Beam connecting rods
MAHLE Powerpack forged Flat top coated piston kit ( to be confirm *cc* )
MAHLE file fite ring set
ACL Race engine bearings
Looks like I need to make sure the rods will work with a "Standard base circle" camshaft .
Any suggestions where I should get all my parts ? ( sponsor here , well known shop etc. ? )
Thanks.
Thanks.
i agree! valve releifs is all you need. call corey at clayton racing. he will tell you exactly what you need and has everything u mentioned. those rods will clear a standard base cam just fine.
