Can this be welded??
Old May 29, 2010 | 12:32 AM
BlackBird87's Avatar
Exclamation Can this be welded??
I rushed and cracked the gear if welded correctly will it hold. It will be turning aftermarket cam,1.6 rrs and better springs
Attached Thumbnails Can this be welded??-dsc01452.jpg   Can this be welded??-dsc01453.jpg   Can this be welded??-dsc01455.jpg
Old May 29, 2010 | 03:43 AM
gregrob's Avatar
Absolutely not worth risking that in my opinion, I would not try to weld it. You could run into balance issues and if it ever came apart it would do a lot of damage.
Trying to cut corners and save a buck now WILL bite you hard later. Plus if you actually figure the cost of having someone weld it then having it balanced you would have more into it than a new gear lol.
You need PN: 10128349 from GM. You can get it from Summit for 60 bucks
Old May 29, 2010 | 05:54 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I agree with you, it is not something that should be done! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old May 29, 2010 | 06:17 AM
enjoi355's Avatar
if thats for the spline driven opti (looks like it from the pics), send me a pm, i got a couple of those laying around in good shape
Old May 29, 2010 | 06:30 AM
gregrob's Avatar
I was gonna offer the one I have laying around as well but I wouldn't mix and match used gears with a new chain etc.
I would replace the whole timing set with new. But that's just me
Old May 29, 2010 | 06:47 AM
SSPerformance's Avatar
Deff whould not weld it
Old May 29, 2010 | 06:49 AM
Badazz 97 TA's Avatar
Hell no! why would you even attempt or ask to fix one of the more important pieces in a engine.
Old May 29, 2010 | 08:15 AM
letsrun97z's Avatar
I got one that's stained like yours may have about the same wear on it lol
Old May 29, 2010 | 08:40 AM
nighthawk15's Avatar
Welding is a bad idea on pretty much anything that rotates, especially at that speed. Even if the weld holds there's pretty much no way it will be properly balanced anymore because the material left from your weld would likely have the same effect as if you put a small weight on it.
Old May 29, 2010 | 08:47 AM
fleetmgr's Avatar
If you wouldn't perform a weld repair on a connecting rod, crankshaft, camshaft etc, you probably shouldn't here either. While it could be made to work, cost would exceed that of a new piece.
Old May 29, 2010 | 10:02 AM
robsquikz28's Avatar
JUst go buy a new one from VATOZONE
Old May 29, 2010 | 10:15 AM
SoxXpupPeT's Avatar
im a welder and DEFINITELY NOT
Old May 29, 2010 | 02:36 PM
96lt1m6's Avatar
Absolutely not!!!!!
Bad idea!!!
Too many people may have a spare sitting around!!
Will cost you more in the long run!!!
Old May 29, 2010 | 09:54 PM
airfix's Avatar
Just wondering... How the hell did you manage to do that??
Old May 30, 2010 | 02:29 AM
AZ2ENVY's Avatar
Whats up with all the hair and debris in the one pic ? I hope when youre doing
the work on your car none of that **** or any other debris makes it into the motor !
Old May 30, 2010 | 03:22 AM
You mean thats bad?? j/k It was sitting on the floor of my car and i leave the windows open and that **** is everywhere.
As for the gear i couldn't find one anywhere, i dont think the one from summit is splined and i was looking for one locally cuz i didnt want to wait. but this thread worked great and i find someone that has one, Thanks for everyones input
Old May 30, 2010 | 02:00 PM
lifeisgood's Avatar
you can balance and weld anything. but like everyone else said. not a good idea. it would be too much money and too much time involved in it, they dont cost that much to replace.
