Cam only dyno numbers.
I'll post the sheet later. It has an amazing tq curve. At 2000 rpm it goes straight to 330ft lbs, climbs to 355 and holds it almost the whole run.
Definitely shows why its so much fun to drive.
We ended up using XFI lobes because they did exactly what we needed to do.
Rough specs are less than 220 intake, and .565 lift on both sides 111+a lot lsa
I took what I learned off this cam and thehammer again HELPED ME design z28camaro30ann's cam and it did 401 with le2 heads untuned and it has an awesome powerband too. Very fun to drive and will pick up even more tq when he's not super lean in the mid range / top as he is now.
I'm overall very impressed with how these XFI cams act. Seems like they get a bad rap because retards want to use the biggest one made and throw it in a stock longblock and when it doesn't perform like they want, everyone says the XFI cams are junk. With some custom tweaks and a GOOD VALVETRAIN the XFI lobes are great. I drive the car a lot, been using it for work lately and driving hundreds of miles a week and the valvetrain is rock solid. You just have to use good components.
Working on scanning the dyno sheet now
Wouldn't you guys have a **** fit then.
I was definately wrong about that!
