Gatorback Serp Belt...anyone? anyone?
I've heard good things about the Goodyear gatorback serp belts. My question is Is there a sponsor on here that stocks these? I like to support sponsors on here when I can. (If not this exact belt is there something comperable? Feel free to discuss experiences good or bad with these belts-my searches didn't yield much.)
Thanks
Thanks
Just got rid of my crappy squealing Dayco belt in favour of the Goodyear. For the record the Dayco was put on last summer driven 1000 miles and then parked for the winter. When I took it off it still had the form of being on the pulleys. Never had that problem with a Goodyear that I used for the last 6 years.
FWIW:
I don't know if I would run a gatorback......or any other brand belt that has "cross-cut" ribs on a LT1. I found out that Ford kept having mysterious crank sensor problems on some vehicles that was eventually traced back to static electricity build up caused by gatorback belts. The local dealership absolutely will not install them on anything with a crank sensor....yet they prefer them to other brands on everything else. I'd never heard of that before or thought about it being possible, but it makes sense that it could happen. If this is so, then I'd bet the static could lead to problems not only on 96-97 models with crank pos sensors, but also problems with the opti-sparks on all our LT1's. Even on the 24x EFI Connection conversions and LS motors I'd think.
Of course this could all be a bunch of crap, but it kinda makes sense that it could happen. Just to be safe, I'm not going to use one myself.
Gatorback = Crap. I had one may years ago on my T/A and it decided to come apart on my at 70mph on the highway. Took out my compressor at the same time by wrapping around the pulley and clutch and destroying the comp clutch. I will never put one on my car again. Just my .02!!!!
FWIW:
FWIW:
I replaced an old belt with a gatorback, because I had one on my old camaro and it never squeaked, but for some reason it got a big split in it from I don't know what. I noticed it while looking at something else under the hood, thankfully it was visible on the top of the alt, otherwise I would not have noticed for some time or until it tore completely. I replaced that with a gates 6 months ago, no more tears so it's probably not a pulley or anything, the belt was bad I think.
I am not saying that Gatorback AND other similarly constructed belts (with crosscut/cooling grooves DO cause static.....or that they will cause trouble. I'm just passing on information I was given about what Ford technicians supposedly found out. Of course, they are the same ones who blamed all the Ford Explorer rollovers on Firestone too. LOL
Most of the other failures...splitting/breakage/etc. that were mentioned above, I have seen or heard from most all belt brands. I honestly couldn't tell you what brand is even on my car. I bought the car a few months back and the belt looks good, i.e. no cracks or dry rot visible....so I just left well enough alone.
If I were buying one right now I'd probably get a kelly springfield (also reboxed as Duralast belts) since that is what we sell, AND they are made by Goodyear who owns Kelly tires. They don't have to extra grooves though. Like I said above....it may be a load of crap....especially considering the source (Ford). But I'd rather not chance it personally when I know standard style belts can last for years.
