track results
Old Jun 5, 2010 | 12:11 AM
1lt1wiz's Avatar
Exclamation track results
hello went to track to night and not happy i ran a best of 14.5 with a 2 somthing rt the car has moroso cold air performabuilt level 2 trans with his 23 2500 stall and a tsp rumbler free mods the problem i have is when i launch it at 2500 it feels like its hitting rev and u have to let up a bit any help would be helpful
Old Jun 5, 2010 | 12:14 AM
WhitePhoenix99's Avatar
Reaction time doesn't effect your et so don't worry about that. What was your 60ft time? Also, trap speed?
Old Jun 5, 2010 | 12:17 AM
dubga's Avatar
Why does your sig say "new time of 13.418" if you just ran a 14.5?
Old Jun 5, 2010 | 12:28 AM
1lt1wiz's Avatar
Default hey
that was befor i had to have the trans rebuilt by frank at performabuilt 2.1 on the 60 mph was 94 befor the rebuild i hit a 13.8 and lost reverse 2 days later
Old Jun 5, 2010 | 01:01 AM
Ok first off it's very difficult to read and understand what you are typing. Puncuation would help a lot. 94mph trap is very low even for a stock auto. This was with the new transmission?
Old Jun 5, 2010 | 10:07 AM
1lt1wiz's Avatar
Exclamation here
ok street tires rt.. was .167
60.. was 2.154
8th.. was 9.358
mph for 8th was 75
1/4 14.542 mph 94
car has texas speed rumbler no cats free mods moroso cold air removed ac been tuned also
Old Jun 5, 2010 | 11:40 AM
1lt1wiz's Avatar
Default hello
bumb to top
Old Jun 5, 2010 | 01:07 PM
TravisMcGill2000's Avatar
get ur shift points moved. You shoudnt have to let out to shift.
Old Jun 5, 2010 | 01:12 PM
LSWHO's Avatar
What year is your car?
Stall wall needs to be tuned out in 93/94/95 I believe.
If it's ODB2 you are gonna need a new tranny...
Old Jun 5, 2010 | 01:25 PM
pittman's Avatar
It is very hard to understand your paragraph-sentence all run together. Sorry.
First, it sounds like to need your new tranny tuned to shift at the correct rpm. A dyno sheet will show you your peak rpm, so set the shift point 200 rpm past peak. I think I am reading that you are hitting the rev limiter instead of a good shift ?
Second, comparing the times you ran before, may be apples to oranges. If the DA, track condition and tires or pressure was different, it can drastically change your ET. I loose half a second and 5mph from fall weather, to summer.
Give some detail on before and after if you really want some opinions.
Pitt
Old Jun 5, 2010 | 03:19 PM
hitmanws6's Avatar
Work on your launch first of all. People on street tires are cutting at least 1.8 sixty foots with bigger stalls
Old Jun 6, 2010 | 12:25 AM
snk-huntr's Avatar
having trouble understanding but sounds like you are hitting the rev limiter, probably needs retuned for the convertor.
Old Jun 6, 2010 | 01:56 PM
LSWHO's Avatar
EDIT: Ok he has OBD1. Need a tune.
