takout catalytic converter on lt1
I haev a 1996 Firebird Formula with an m6 and slp loudmouth 1 cat back. What would be the benefits and negatives to taking the catalytic converter out of my car? some people tell me ill lose power, some say my power range will change and ill get more horsepower but a little less torque. know i wont pass inspection, but how will it sound and perform compared to now?
Remove it if you can get past emissions. Get a tune if you want but any power "lost" wont outweigh the weight loss especially if you have 2 cats.
Power loss is minimal I forget it but its either +/- 1-2 rwhp or +/1-2 rwtq a combo of one of those loss and gain.
If its cheap and easy take it out....however im not sure it will sound good with your exhaust setup. I would more take it out for the postive exhuast sound it would make on a normal style catback.
I know that on average you won't gain much on a still restrictive exhaust..
Now, I got Long tubes and an ORY on now.. and it sounds 10x better then it did with my last combo..
and of course you run the chance of failing inspection.. unless you buy a decal
^^yeah if your going to remove it remove it, don't gut it. if you need to pass visual get one of these> http://www.frozenboost.com/index.php...180c9f2fad063c
a gutted cat disrupts the airflow and prolly makes you loose a couple hp and def won't help w/ the LT1 poppin
