95Z28 a/c not working. HELP!!!
Old Jun 26, 2010 | 01:50 PM
Slowmaro95Z28's Avatar
Default 95Z28 a/c not working. HELP!!!
I got a 95 Z28 that I just got back on the road after building a new motor and now my a/c won't work. It just blows hot air. I checked for leaks, checked for power at the a/c fuse, the HVAC fuse, and the a/c relay. Everything checks out and all wires are in perfect condition. I'm lost here. Can anyone help me?
Old Jun 26, 2010 | 02:40 PM
lethal bird's Avatar
I had this same problem after i put my longtubes on. Check in front of the a/c compressor and make sure there is nothing keeping the outer a/c pulley from spinning. I had an a/c line that had gotten wedged on the side of the pulley and it was keeping the outer pulley from moving. That was what happen to me. Dont ask me how that happen to mine i still dont know. I hope thats all it is and not anything to serious and costly.
Old Jun 26, 2010 | 02:43 PM
There isn't anything in the way at all. I checked all that before I started the new motor for the first time.
Old Jun 26, 2010 | 02:47 PM
Z28Roxy's Avatar
Does your compressor engage?
Old Jun 26, 2010 | 02:48 PM
Not at all. Doesn't sound like the relay is working either. Maybe bad switch?
Old Jun 26, 2010 | 03:28 PM
fleetmgr's Avatar
Are the wires plugged into the compressor?
Old Jun 26, 2010 | 03:32 PM
SoxXpupPeT's Avatar
you coulda run outta refrigerant.. that would prevent the compressor from engaging..
Old Jun 26, 2010 | 04:02 PM
Z28Roxy's Avatar
Only if he has a leak...
If his compressor isn't engaging he either has no freon (ie has a leak), has a problem with the wiring related to the compressor, or the compressor itself is bad.
Old Jun 26, 2010 | 08:10 PM
Everything is plugged in like it should be. I got power to the fuses and relay. There are no leaks and the freon or whatever it is now is full. Could this be a problem in my switch in the car? Is there an easy way to test for this? When I turn the a/c on I don't hear the relay.
Old Jun 26, 2010 | 08:20 PM
fleetmgr's Avatar
Jump the compressor clutch straight to the battery to see if it engages, for starters.
Old Jun 26, 2010 | 08:21 PM
Good call. I'm so worried about the other end I didn't think to try that. Thanks.
