Bleeding Clutch, power bleeder?
Old Jul 27, 2010 | 01:03 AM
nik1703's Avatar
Default Bleeding Clutch, power bleeder?
I have some air in the hydraulic system, the slave is leaking - so I'm assuming that's the issue. Anyway, since there is no bleeder valve on the slave, how do I go about bleeding it? Do I pick up one of those power bleeders at autozone and hook that up to the reservoir?
Old Jul 27, 2010 | 01:04 AM
nik1703's Avatar
also will replace the slave, obviously..
Old Jul 27, 2010 | 01:39 AM
96lt1m6's Avatar
would just replace the entire system
http://www.ws6project.com/user_stor/...th=236_262_288
Old Jul 27, 2010 | 02:28 AM
nik1703's Avatar
even if i replaced both master and slave, i'd need to bleed it after. that's what im asking.
Old Jul 27, 2010 | 02:47 AM
96lt1m6's Avatar
If you purchase the above set up from ws6 store it is pre-bled since there is no true way to properly bleed the system,many have tried some work ok but still not the way it should.
Old Jul 27, 2010 | 03:12 AM
nik1703's Avatar
interesting.
i'd also like to mention that i'm selling the car, so.. spending 160$ on a master/slave is not a favorable option if i can just bleed it out somehow
Old Jul 27, 2010 | 02:57 PM
nik1703's Avatar
question guys, will this work?
http://www.performanceworks1.com/ls1...h_bleeding.htm
Old Jul 27, 2010 | 03:21 PM
AChotrod's Avatar
I hand pumped the slave until all the air was out.
Old Jul 27, 2010 | 03:33 PM
idformula's Avatar
How do you figure? If you replace the master cylinder, your supposed to bench bleed the master, and on top of the slave is a bleeder valve.
How to bench bleed
http://www.therangerstation.com/tech...leedclutch.htm
This is on a truck but the principals apply.
Old Jul 27, 2010 | 03:45 PM
DAVE00's Avatar
+1 - Get some good leather gloves on and pump away. Man that sounded dirty -
Old Jul 27, 2010 | 03:54 PM
96lt1m6's Avatar
How to bench bleed
There is no bleeder on Lt1s
If you read the link i provided you will see in the notes that the slave comes pre-bled. i have bought a few and they all come ready to instal.
93-97 LT1 GM Master & Slave Cylinder
[12559912] $158.99
Click to enlarge
It is advised to replace this unit whenever you replace the clutch. This unit contains the master cylinder and slave cylinder in one unit pre-bled from GM.
Old Jul 27, 2010 | 04:06 PM
nik1703's Avatar
well guys i went ahead and bought the mityvac pump from autozone that i posted above. i'll give it a shot and report back
Old Jul 27, 2010 | 07:33 PM
nik1703's Avatar
reporting back after using the mityvac on the master cylinder in the engine bay, that thing didn't do ****.
back to the drawing board.
Old Jul 27, 2010 | 08:36 PM
Low N Slow's Avatar
Did you try pumping the slave like a couple people suggested earlier in this thread?
That's the only way to get air out of the slave and the line.
Old Jul 27, 2010 | 09:14 PM
nik1703's Avatar
so, hook up mityvac, create vacuum, remove slave from tranny, pump slave plunger?
doesnt pressing the clutch while i hook up the vacuum do the same thing?
also - my symptoms are... clutch loses pressure as it is held down. it is firm for the first few seconds, then loses pressure and clutch engages.
Old Jul 28, 2010 | 12:31 AM
Low N Slow's Avatar
The pressure lose is from the fluid leaking out of the slave, don't bother bleeding it until you replace the slave.
Old Jul 28, 2010 | 11:12 AM
AChotrod's Avatar
Yep^^You need a new slave. The mighty vac was a waste of money IMO. Ive never had good luck using them.
Old Jul 28, 2010 | 11:19 AM
DAVE00's Avatar
Why do you continue to insist on using the Mighty Vac when numerous people said not to? Pump the **** out of it as that is what we all do since there is no bleed valve for the LT1 setup. It works - trust me as I've replaced mine twice and never had an issue. It does suck that it takes long and beats the hell out of your hand, but it is the tried and true method for our cars.
Old Jul 28, 2010 | 11:23 AM
AChotrod's Avatar
100% correct!!^^ Or just buy the entire slave and master and call it a day. Its not that expensive and you already prob wasted 20-30 on the MV
Old Jul 28, 2010 | 12:35 PM
LilJayV10's Avatar
I was about to post the same thing. I thought I was the only one that couldn't find a bleeder valve in the system. Why in the hell would they that?
My friends clutch fluid needs to be changed and there no way he is going to by a new slave to do that.
