fuel pump hatch door
I consider myself a fairly compitent 'driveway mechanic', been wrenching on cars pretty seriously, since the late 60s. The f/p on my '96 Z-28 had gotten a little noisy earlier this summer, so after pondering and researching the job for a while, I decided to tackle it. My car is by no means an old 'hoopty', and it isn't a track car, so I didn't really want to cut up the floor.
This past Wednesday, I got the car up on the jackstands, pulled the muffler, the panhard bar and its upper support, got the exhaust pipe and heat shields out of the way, removed the shocks and sway bar links, and the rear tires.
Bright and early yesterday, I crawled back under the car, unbolted the brake line "y" adapter for some extra room to drop the axle, lowered the axle, dropped the tank straps, supported the tank, wresteled with the fuel line connections for quite a while, as they're not easily reached, but finally got them off, and then tried to remove the tank....I can't get it out....There just isn't enough room!
Does the rear axle have to be disconnected (drive shaft off, LCAs unbolted, etc) and moved out from under the car, in order to be able to twist the tank out??
As I said, I really don't want to cut up the car........
Any tips would be greatly appreciated, as I'm about ready to "send it out" to get this done, as my creaky old azz is sore from all of the lifting and stretching I did yesterday, but I know it will be $$$$.
Assuming you cover the hole once it's been cut, there's no additional road noise.
Personally,i find the mod conveinent but how often do you have to access a fuel pump? no answer required!
I don't mind a properly done mod but i have seen some seriously bad "HACK JOBs" the mod done above and many others are nicely done. Maybe at some point i will do this mod................
Lazy way
